Originally Posted By: stxonall8
Never towed ever bought new, I have 36000 on it now and better yet ever time I get it back I wont go on the freeway for the first 75 or so miles I wont even go over 50mph and i vary my speed they claim it is the limited slip.
This may be the last thing you want to hear, but:
A limited slip diff (LSD) is a wear part, very sensitive to clutch pack wear, adjustment and lubricant. They are prone to malfunction. Is the LSD your problem area?
If you want a full locking diff get either an ARB air locker (~$1100 + installation), or, if you have 4WD and will use it in any icy situation, either a Lockright (cheaper) or a Detroit Soflocker (unbreakable, preferred).
If you don't care about traction get an open differential. If installed correctly and lube is changed every 50-80K mi, they last a very long time.
Charlie
