What 0W-16 are you using?
Dude, stop picking on typos. Come on man, I'm not typing my resume here. You guys have a lot of time, seriously 🤦‍♂️ Just follow what Toyota says and you will be fine. Toyota oil filter costs 5 bucks
Aftermarket oil filters are built to have the same features in terms of size, bypass valve pressure...etc as OEM. However, they often have more efficient media, just like the TRD filters which I've mentioned several times now and you keep side-stepping.
These geniuses want to run HPL fluids in a Toyota minivan 🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️
I know you will take this badly, but it would help if you learned a bit of technical understanding before you continue to post complete nonsense as you are now doing in this thread. You are clueless here and way out of your wheelhouse to the point of becoming ridiculous.
TRD is a scam developed here in America, crap is bolted onto Toyotas at the port. Also, Toyota engineers decided more effecient media is not necessary to get a million miles from their motor, stop wasting your money on Wix XP and other crap, Toyota filter costs 5 bucks 🤷‍♂️
Wix XP are actually poor efficiency filters, which you'd have known if you'd spent more than 5 seconds on this forum and taken the time to visit the filtration sub-forum rather than endlessly running at the mouth about a subject you clearly know little about 🤷‍♂️
If one is to make a troll account to achieve maximum trolling this is how you do it.
It is you guys who are trolling. OP started this thread asking about which is the best 0w16 oil, and nobody answered his question. You got into this old stupid boring thick versus thin debate
Bet a hundred it's a troll account. It's only 2 days old and there's no way one can genuinely this abrasive.
It is you guys who are trolling. OP started this thread asking about which is the best 0w16 oil, and nobody answered his question. You got into this stupid boring thick versus thin debate
Plenty have said to use 0w-16 and have given their recommendations, no need to make stuff up. On top of that you can use many grades above 0w-16 as it's the minimum not the maximum.
My owners manual says to stick to OW-16, use 0W-20 if 16 is not available but next Oil Change switch back. I don't know what manual are you reading
From North Dakota in the winter to utah, Arizona and Nevada in the summer, I have had zero issues whatsoever with the 0w-16, and my van is still running solid at 163,000 miles. Trust the engineers who designed your motor, and you will be perfectly fine
