Originally Posted By: Nissan101
A few drops as the heavy rainfall that got on the funnel and entered the transmission. But it was like for
only 20 seconds before
i closed the bonnet
I ran it for two days and
the oil is still cherry red not milky. Is it ok to use it like this?
nope what i have been doing was the everyday since this happen when i arrive at work and when i arrive home i would
take out the dip stick to allow any moisture to be removed.
And
i do 150km a trip,
mostly highway though
Originally Posted By: philipp10
we are talking maybe, maybe a teaspoon of water.......Wouldn't the fluid look milky if it had enough water in it?
a )OP has mentioned at post#1 .........
A few drops .. for
only 20 seconds..before
i closed the bonnet ..............Philipp10 , you are absolutely spot on suggesting :it may be, may be ..a teaspoon of water.
b )Now at 1 teaspoon of water(with my rudimentary explanation), it ONLY contributes to about 600 ppm of water in the oil sample .. which is
well below conservative safe limit of say , Blackstone Labs (with attached sample report), of 1000 ppm (0.1%)..... meaning the 600 ppm of water are '
dissolved water in lubricant oils'..... rendering its continuing serviceability as originally intended.Dissolved water does
not render condemnation of oils.
c )At water content (substantially) higher than 1000 ppm , the oil colour will appear cloudy .... until such time the ppm increase of dissolved water (being part of oil) has reached a state of saturation within oils ..... beyond which 'free water' is forming within (and separate from ) the oil sample ... The separation of 'free water' from the oil sample renders heavy cloudy/milky colour one sees in an oil sample.
d )I would be less generous than you ...... in estimating the OP's water contamination, if any. My estimate would be in the range of 100-200 ppm ............. which is a NON-issue in condemning the oils ..... I repeat!
e )In post #1, OP has separately mentioned :I ran it for two days and
the oil is still cherry red not milky ........... a strong indication of total absence of 'free water' in the oils.
Why wouldn't it just evap off with the dip stick out....and contaminents....come on, whats really going to get in there.
f )Your suggestion of exposing dipstick when hot ... to release water vapour ,if any,makes for perfect sense.It's practical and realistic.
g )Non-water contaminants (of air-borne nature ?) ingressing into oil sump through 'temporarily removed' dipstick ....... OMG , that's stretching my ........
OP, evaluate for yourself, I've no doubt whatsoever .... your oil IS good to go.
If need be ,please continue doing what you did :"nope what i have been doing was the everyday since this happen when i arrive at work and when i arrive home i would
And
i do 150km a trip,
mostly highway"
From Brybo86,
http://www.bobistheoilguy.com/forums/ubb..._AT#Post2405713
Note: I would strongly appreciate sticking to the (facts of the) case .... and not digressing away into .....
