Was a Fram user But never again!
im with ya on the purolators can seems flimsy, does to me too, however a while back daman cut open several filters including p1 and proved me wrong, if you look on here im sure youll find it, very interesting
Quote:
I'm the opposite: I started using Fram Extended Guard a few years back. In my opinion, you cannot get a more robust filter. I buy my Fram Extended Guard filters at Fleet Farm for around $8.....
Normally at Wally, the largest seller of XG, it is a few pennies shy of $9
Quote:
So I'm spending maybe 2 bucks more for a filter that is built 10 times better, and being used on a vehicle valued at $20,000 or more. Using a less sturdy filter to save $2 makes no sense to me.
10 times better than P1? Based on what? Can't be efficiency. Perhaps you meant rated holding capacity, but that is about two times greater, not 10. And river rats testing here showed P1 to filtration/flow to be right up there with the best.
As for the P1 cost, while the regular price is $6-6.50, it's frequently discounted. AAP now has them for $5, with an online code $3.30-$3.50. So now one can buy 2 P1's for less than the cost of one XG. As for can thickness, XG may be thicker, don't know, but in my experience, ~40 years in PC use, never had an issue with any oil cans thickness being an issue.
Quote:
The clincher is I am buying an American product.
As pointed out above, while it may (or not) continue to be made in the USA, it's no longer American owned. Fwiw, though foreign owned, Purolator oil filters are made in America.
I will say, based on it's construction, the XG is only filter made by Fram that is close to being worth the price, especially when used for it's intended 10K OCI's. But, seeing as the OP's topic was the orange can, the XG wasn't really his focus. And making the P1 appear less than the excellent bang for the buck filter that it is, to make the XG look good, shouldn't be the point either, IMO.
Originally Posted By: Colt45ws
I seen a whole case of PH2s that were not threaded at all. Shame I didn't get a picture. It happens.
Yes, it seems on the internet that the more fantastic a story, the less likely anyone has pictures.
So, do we think that maybe the threads on the can stopped?
^^Oh,and my previous post is meant in jest. Fram TG`s give me the highest and most consistent oil pressure. Excellent filters imo.
The higher oil pressure is probably a result of more restrictive filter media and in most case that is not a good thing.
You can't get higher oil pressure with a more restrictive system unless the oil pressure gauge is located before the filter ... which in most engines, it is not located there but rather after the filter.
And besides, with a positive displacement oil pump the oil pressure after the filter should be the same regardless of how restrictive the filter is if the oil pump is not in pressure relief and not totally worn out (meaning not losing pressure with volume output due to worn/leaky parts). The only time you would see an oil pressure reading difference with a sensor located after a more restrictive oil filter is when the pump is in max pressure relief mode.
Originally Posted By: aquariuscsm
I bought a Fram TG yesterday for my next oci. Will my engine be ok?
No, it will immediately explode. Have you seen a mob hit with a car bomb. Exactly like that.....only orange in color.
Actually, with TG, you may be able to get to the end of your driveway first (the power of metal endcaps, you know!!).
Haven't you been paying attention to the rigorous scientific testing and reasoning on this website?!?!?!!
Quote:
...Something I notice is that AutoZone likes giving away OCOD oil filter for publicity.
Must be true then, even bad publicity is better than none at all. Also the reason that Advance has IMO, the better oil/filter change promos. Orange can or Purolator Classic, tough call.
