Hi all,
First time poster here. About a year ago I did 2 drains and fills with supertech Dexron 6 (2001 BMW 330xi). Well, I had a mechanic do the fills cause I had messed sth up. No trans problems. I just want to make sure fluid is at the proper level. Not sure if the mechanic kept the engine running after shifting through the gears.
Now, since supertech Dexron 6 was discontinued. Can I top up with the new supertech Dexron 6/mercon 5 multi vehicle ATF, or for instance w the acdelco Dexron 6. Essentially mixing one of the 2 new fluids w the supertech Dexron 6?
Cheers,
Fana
Cheers,
Fana
