Hello BITOG,
I have been a long time lurker but finally decided to register. I have a question regarding servicing the transmission filter, specifically the "paper/felt" material filter module inside the pan of a Toyota-Aisin U660 6 speed transmission on a 2014 Toyota Camry V6. This is commonly used in Toyota Camry V6s, Siennas and the like.
I did one "fluid exchange" at the dealer at around 100,000 KM (60k miles), and one drain and fill at around 120k KM (I didn't trust the dealer actually did the work in hindsight). For my DnF, I used a mix of Pennzoil Platinum Dex VI and SuperTech Dex VI (5:1 ratio). I am a firm believer of no-such-thing-as-lifetime-fluid, but not so sure about a lifetime paper trans filter.....
My main concern is, the pan still has its original seal and is bone dry after all these years. I do not want to fix something that isn't broken, so cracking open that seal just to replace the trans filter may not be worth it if it may cause leaks down the line. Should i wait for the pan to start leaking and do the pan drop, or should i do it regardless at the next opportunity (likely 200,000km, 124k miles).
Thanks in advance!
Thanks in advance!
