The Answer is Yes. Matter of fact even the low sulpher we have now is not good for the TDI, just take a look at some of the pictures of sooted up intakes from the crappy diesel we have here.quote:
Originally posted by srivett:
msparks: Would it hurt your ULSD car to run a high sulfur content?
Steve
Boy it is about time VW fixed there engineering screw up's. Boy the Germans are slow. Hi Ted buy it If you don't mind buying a boat anchor 3300 lbs. yikes!!! Danquote:
it has chain driven cams, along with a healthy 6.3 quart oil capacity/10 quart, coolant capacity
the dark ages of the late 70s.....I remember when mom's buick had 400+HP......quote:
Originally posted by VaderSS:
I remember when big V8s were only making 150.
So FowVay, what is the "chassis nomenclature" for the soon retiring B5/B5.5 Passat then..."internally"?quote:
Originally posted by FowVay:
The chassis nomenclature for the A5 Jetta is internally known as the PQ35 in case you weren't aware.
Volvo's 5 cylinder does not use VVT in non turbo form.quote:
Originally posted by Winston:
The Volvo engine gets more hp because it has variable valve timing. I do not think the VW has that. About 60hp per liter is about all you get. To get much more you need variable valve timing, and/or variable intake, or turbo, or supercharger, etc.
Sequentially, the nomenclature for the B5/B5.5 chassis is PQ45. The first digit (4) is the chassis, the second digit (5) is the generation.quote:
The vehicle identification number will simply identify which engine your platform was equipped with. It won't identify which specific engine code was installed. It will identify whether your platform was equipped with a 1.8T, a 2.8 V6, a 2.0 TDI or a 4.0 W8. The 1.8T was available in one of the four following codes: AEB, ATW, AUG, AWM. This code is stamped on your engine casting on the front of the block.quote:
Btw, can you identify the 1.8T engine code of my B5 if I give you my vin(playin' devils advocate
Boy..are you a fountain of VW info! With that much VW knowledge you could actually make a career out of it.quote:
The 2.8 V6 was available as one of the two following codes: AHA, ATQ.
The W8 engine code is a BDP and the TDI engine code is BHW.
This data isn't deciphered via the VIN.
