Here is the oil info from Audi (Owns VW and uses the same 1.8 Turbo motor as in my Passat in some Audi Models.
Viscosity
Engine oil is manufactured in different viscosities to meet the
requirements of various engines. The correct viscosity grade
for your engine also depends on climatic or seasonal conditions
where you drive. You can use oil with a viscosity of SAE 5W40
across all temperature ranges for normal driving conditions.
However, if that grade is not available, you can use SAE 5w30
or SAE 0W-40, as long as it meets one of the Audi oil quality
standards specified to the left. Because Audi approved engine oil
may not be available everywhere, we recommend that you always
carry with you an extra quart (liter).
For more information about engine oil that has been approved for
your vehicle, please contact either your authorized Audi Dealer or
Audi Customer Relations at 1 (800) 822-2834, or visit our Web site at
audiusa.com. The Web site can provide you with a current list of oils
(manufacturers, brand names, etc.) that conform to Audi oil standards.
List of Audi approved oil:
Technical Service Bulletin
Page 1 of 9 plus attachment
© 2013 Audi of America, Inc.
All rights reserved. Information contained in this document is based on the latest information available at the time of printing and is subject to the copyright and other intellectual property rights
of Audi of America, Inc., its affiliated companies and its licensors. All rights are reserved to make changes at any time without notice. No part of this document may be reproduced, stored in a
retrieval system, or transmitted in any form or by any means, electronic, mechanical, photocopying, recording, or otherwise, nor may these materials be modified or reposted to other sites, without
the prior expressed written permission of the publisher.
17 Engine oils that meet Audi Oil Quality Standards 501 01, 502 00, 505 00, 505 01, and 504 00/507 00
17 13 35 2010043/13 January 9, 2013. Supersedes Technical Service Bulletin Group 17 number 12-29 dated
June 26, 2012 for reasons listed below.
Model(s) Year VIN Range Vehicle-Specific Equipment
all 1997-2014 all Not Applicable
Condition
REVISION HISTORY
Revision Date Purpose
13 - Revised Service (MY 2014 R8 V10 info added)
Revised Header (Added model year 2014)
12 6/26/12 Revised header data (Added model year 2013)
11 6/6/2011 R8 GT required oil VW 501 01 and 505 00, added to list
10 6/18/2010 Revised header data (Controlling TSB display in ElsaWeb)
9 6/24/2009 Revised Service
8 4/6/2009 Revised header data (Added 2009 - 2010)
Revised Condition
Revised Service
7 11/21/2008 Revised Title to include Repair Group
Engine oils that meet Audi Oil Quality Standards VW 501 01, 502 00, 505 00, 505 01, and 504 00/507 00.
Technical Background
Not applicable.
Production Solution
Not applicable.
Page 2 of 9 plus attachment
Service
Oil Quality
All Audi engines must always use engine oils that conform to the applicable Audi Oil Quality Standard. No other
engine oils may be used. This also applies when topping off engine oil between services.
Recommendation for Customers
It is recommended that the customer always carry a spare quart/liter of engine oil that conforms to the applicable
Audi Oil Quality Standard in case the engine oil needs topping off while on the road. The spare quart/liter of oil
should be stored in its original container, securely closed in the luggage compartment. Ensure the container is
securely stowed.
Note:
Use of the wrong oil may damage the engine. Damage caused by using the wrong oil will not be covered by the
applicable vehicle warranties.
Approved Engine Oils
Below are the lists of engine oils that currently meet Audi Oil Quality Standards VW 501 01, VW 502 00, VW 505
00, VW 505 01 and 504 00/507 00.
The first four lists of products are comprised of oils that meet Audi Oil Quality Standard VW 501 01, VW 502
00, VW 505 00, VW 505 01, or VW 504 00/507 00 and are generally available in the North American market at
the time of publication. The attachment lists products that meet Audi Oil Quality Standard VW 501 01, VW 502
00, VW 505 00, VW 505 01, or VW 504 00/507 00 available worldwide at the time of publication.
Please refer to the specific Vehicle Owner’s Manual, published Technical Service Bulletins and Fluid Capacity
Charts to select the appropriate oil required for each Audi vehicle.
The lists below are also posted on
www.audiusa.com and
www.audicanada.ca.
PRODUCTS GENERALLY AVAILABLE IN NORTH AMERICA
Audi Oil Quality Standard VW 501 01 VW 505 00 is used exclusively for the R8 GT and MY 2014 R8 V10
only.
Audi Oil Quality
Standard Manufacturer Oil Type Viscosity
VW 501 01
VW 505 00
Castrol
Edge Professional TWS
Part Number: G 052 194 1L DSP
SAE 10W-60
Page 3 of 9 plus attachment
Audi Oil Quality Standard VW 502 00
Audi Oil Quality
VW 502 00 Castrol ZVW 352 167 SAE 5w30
VW 502 00 Castrol ZVW 352 540 SAE 5W-40
VW 502 00 Agip Agip synthetic PC SAE 5W-40
VW 502 00 Blu Lubricants Inc. Blu Synthetic-Technician Series
FS SAE 5w30
VW 502 00 Bucher AG MOTOREX Select LA-X SAE 5w30
VW 502 00 Caltex Caltex Havoline Fully Synthetic SAE 5W-40
VW 502 00 Castrol SLX Professional Longtec SAE 0W-40
VW 502 00 Castrol SLX Professional OE SAE 5w30
VW 502 00 Castrol Syntec European Formula SAE 0W-30
VW 502 00 Castrol TXT 505 01 SAE 5W-40
VW 502 00 Castrol Syntec SAE 5W-40
VW 502 00 Cepsa Cepsa Star Mega Synthetic SAE 5W-40
VW 502 00 Chevron Havoline Ultra SAE 5W-40
VW 502 00 Chevron Havoline Ultra S SAE 5w30
VW 502 00 Chevron Havoline Ultra S SAE 5W-40
VW 502 00 Delek Delek Motorsynth FE SAE 5w30
VW 502 00 Delek Delek Motorsynth TDI SAE 5W-40
VW 502 00 Elf Elf Excellium Full tec SAE 0W-30
VW 502 00 Elf Elf Solaris LSX SAE 5w30
VW 502 00 Fuchs Fuchs TITAN GT 1 SAE 5w30
VW 502 00 Fuchs Fuchs TITAN Supersyn SAE 5W-40
VW 502 00 Fuchs Fuchs TITAN Supersyn PLUS SAE 5W-40
VW 502 00 Fuchs Titan GT1 SAE 5w30
VW 502 00 Igol Process Compact M SAE 5w30
Page 4 of 9 plus attachment
VW 502 00 Liqui Moly Liqui Moly Leichlauf HC 7 SAE 5W-40
VW 502 00 Liqui Moly Liqui Moly Profi Premium SAE 5W-40
VW 502 00 Liqui Moly Liqui Moly Syntheticoil Longtime SAE 0W-30
VW 502 00 Liqui Moly Liqui Moly Diesel High Tech SAE 5W-40
VW 502 00 Liqui Moly Liqui Moly Nachfüll-Öl SAE 5W-40
VW 502 00 Liqui Moly Liqui Moly Pro-Engine M 400 SAE 5W-40
VW 502 00 Liqui Moly Liqui Moly Top Tec 4100 SAE 5W-40
VW 502 00 Lotos Lotos Quazar SAE 0W-30
VW 502 00 Lotos Lotos Quazar SAE 5W-40
VW 502 00 Lotos Lotos Quazar SAE 5w30
VW 502 00 Meguin megol Motorenoel Low Emission SAE 5W-40
VW 502 00 Meguin megol Motorenoel Super
Leichtlauf Multisynth SAE 0W-30
VW 502 00 Meguin Motorenoel Ultra Performance
Longlife SAE 5W-40
VW 502 00 Mobil Mobil 1 SAE 0W-40
VW 502 00 Mobil Mobil Syst S Special V SAE 5w30
VW 502 00 Motul Motul 8100 X-cess SAE 5W-40
VW 502 00 Motul Motul 8100 X-clean SAE 5W-40
VW 502 00 Motul Motul 8100 X-max SAE 5W-40
VW 502 00 Motul Motul Specific 505 01 502 00 505
01 SAE 5W-40
VW 502 00 Northland Synergy Synthetic EuroSyn SAE 5W-40
VW 502 00 Pennzoil Platinum European
Formula SAE 5W-40
Formula Ultra Diesel SAE 5w30
VW 502 00 Pennzoil Platinum Low SAPS SAE 5w30
VW 502 00 Pennzoil Synthetic European
Formula SAE 5W-40
Page 5 of 9 plus attachment
VW 502 00 Pentosin Pento High Performance SAE 5W-40
VW 502 00 Pentosin Pento High Performance II SAE 5W-40
VW 502 00 Pentosin Pentospeed VS* SAE 0W-30
VW 502 00 Pentosin Pentosynth HC SAE 5W-40
VW 502 00 Quaker State Q European Engine Ultra Diesel SAE 5w30
VW 502 00 Quaker State Q Horsepower Full Synthetic SAE 5W-40
VW 502 00 Quaker State Q European Formula Ultra SAE 5w30
VW 502 00 Quaker State Q State Synquest Low SAPS SAE 5w30
VW 502 00 Redoil Italia Challoils SAE 5W-40
VW 502 00 Shell Shell Helix Ultra SAE 5W-40
VW 502 00 Shell Shell Helix Ultra AX SAE 5w30
VW 502 00 SK energy ZIC RV SAE 5w30
VW 502 00 SK energy ZIC XQ SAE 5W-40
VW 502 00 SK energy ZIC XQ RV SAE 5W-40
VW 502 00 Statoil Statoil PRO Synthetic C SAE 5W-40
VW 502 00 Total Total Ouartz 9000 Energy SAE 5W-40
VW 502 00 Total Total Ouartz 9000 Energy SAE 0W-30
VW 502 00 Total Total Quartz INEO MC3 SAE 5w30
VW 502 00 Valvoline Valvoline SynPower HST SAE 5W-40
VW 502 00 Valvoline Valvoline SynPower MST SAE 5w30
VW 502 00 VAPS Vapsoil SAE 5w30
Page 6 of 9 plus attachment
Audi Oil Quality Standard VW 505 01
Audi Oil Quality
VW 505 01 Castrol G 052 167 A2 SAE 5W-40
VW 505 01 Blu Lubricants Inc Blu Synthetic-Technician Series FS SAE 5w30
VW 505 01 Bucher AG MOTOREX Select LA-X SAE 5w30
VW 505 01 Castrol SLX Professional OE SAE 5w30
VW 505 01 Castrol TXT 505 01 SAE 5W-40
VW 505 01 Chevron Havoline Ultra S SAE 5W-40
VW 505 01 Delek Delkol Motorsynth TDI SAE 5W-40
VW 505 01 Elf Elf Solaris LSX SAE 5w30
VW 505 01 Fuchs Fuchs TITAN Superssyn PLUS SAE 5W-40
VW 505 01 Liqui Moly Liqui Moly Diesel High Tec SAE 5W-40
VW 505 01 Liqui Moly Liqui Moly Nachfüll-Ölo SAE 5W-40
VW 505 01 Liqui Moly Liqui Moly Pro-Engine M 400 SAE 5W-40
VW 505 01 Liqui Moly Liqui Moly Top Tec 4100 SAE 5W-40
VW 505 01 Meguin megol Motorenoel Low Emmission SAE 5W-40
VW 505 01 Mobil Mobil Syst S Special V SAE 5w30
VW 505 01 Motul Motul 8100 X-clean SAE 5W-40
VW 505 01 Motul Motul Specific 505 01 502 00 505
01 SAE 5W-40
VW 505 01 Pennzoil Platinum European Ultra
Diesel SAE 5w30
VW 505 01 Pennzoil Platinum Low SAPS SAE 5w30
VW 505 01 Pentosin Pento High Performance II SAE 5W-40
VW 505 01 Pentosin Pentosynth HC SAE 5W-40
VW 505 01 Quaker State Q European Engine Ultra Diesel SAE 5w30
VW 505 01 Quaker State Q Synquest Low SAPS SAE 5w30
Page 7 of 9 plus attachment
VW 505 01 Redoil Italia Challoils Ultrasynt SAE 5W-40
VW 505 01 Shell Shell Helix Ultra AX SAE 5w30
VW 505 01 Statoil Statoil PRO Synthetic C SAE 5W-40
VW 505 01 Total Total Quartz INEO MC3 SAE 5w30
VW 505 01 Valvoline Valvoline SynPower HST SAE 5W-40
VW 505 01 Valvoline Valvoline SynPower MST SAE 5w30
VW 505 01 VAPS Vapsoil 505 01 SAE 5w30
VW 505 01 Lotos Lotos Quazar C3 SAE 5w30
VW 505 01 Lotos Lotos Quazar SAE 5W-40
VW 505 01 YPF Elaion Full Performance SM SAE 5W-40
VW 505 01 YPF Elaion Full Performance Tdi SAE 5W-40
VW 505 01 YPF Elaion Plus SAE 5W-40
Page 8 of 9 plus attachment
Audi Oil Quality Standard VW 504 00 / 507 00
Audi Oil Quality
VW 504 00 /
507 00
Castrol GAU 052 195 M2 SAE 5w30
VW 504 00 /
507 00
Castrol G 052 195 1L SAE 5w30
VW 504 00 /
507 00
BP BP Visco 7000 Longlife III SAE 5w30
VW 504 00 /
507 00
Castrol SLX Professional Longlife
III SAE 5w30
VW 504 00 /
507 00
Denicol Denicol SYN Extra Long Life III SAE 5w30
VW 504 00 /
507 00
Elf Elf Solaris LLX SAE 5w30
VW 504 00 /
507 00
Liqui Moly Liqui Moly Pro-Engine M 600 SAE 5w30
VW 504 00 /
507 00
Liqui Moly Liqui Moly Top Tec 4200 SAE 5w30
VW 504 00 /
507 00
Meguin megol Motorenoel Compatible SAE 5w30
VW 504 00 /
507 00
Mobil Mobil 1 ESP Formula SAE 5w30
VW 504 00 /
507 00
Morris Lubricants Multilife V-MAX SAE 5w30
VW 504 00 /
507 00
Pennzoil Platinum VX SAE 5w30
VW 504 00 /
507 00
Pentosin Pento Super Performance III SAE 5w30
VW 504 00 /
507 00
Quaker State Q Diesel Plus SAE 5w30
Page 9 of 9 plus attachment
VW 504 00 /
507 00
Quaker State Q European Engine VX SAE 5w30
VW 504 00 /
507 00
Sinopec Great Wall Ultra Gold V5457 SAE 5w30
VW 504 00 /
507 00
Statoil Statoil LazerWay LL SAE 5w30
VW 504 00 /
507 00
Total Total Quartz Ineo 504/507 SAE 5w30
Warranty
This TSB is informational only and not applicable to any Audi warranty.
Additional Information
All parts and service references provided in this TSB are subject to change and/or removal. Always check with
your Parts Department and service manuals for the latest information.
This attachment lists products which meet Audi Oil Quality Standard VW 502 00, VW
505 01, or VW 504 00/507 00 and are generally available worldwide at the time of
publication.
Note: Not all oils listed may be available in North America
Page 1 of 10 3/6/09
©2009 Volkswagen Group of America, Inc. It has always been Audi's policy to continuously improve its
products. Audi, therefore, reserves the right to make changes in design and to make additions or
improvements to its products without incurring any obligation to install them on products previously
manufactured. Text and specifications in this Supplement are based on information and knowledge
available at the time of printing. All rights are Reserved. No Part of this document may be reproduced or
translated in whole or in part without the written consent of Volkswagen Group of America, Inc.
Specifications are subject to change without notice. If you are not sure which oil to use, consult with your
authorized Audi Service Advisor.
ACT Voltronic Motor Oil SAE 5W-40
Adamol Adamol Multitop PDI SAE 5W-40
Adamol Adamol Multitop VSI SAE 0W-40
Addinol Addinol Eco Light SAE 5W-40
Addinol Addinol Super light MV 0546 SAE 5W-40
Addinol Extra Light MV 038 SAE 0W-30
Addinol Extra Power MV 0538 LE SAE 5w30
Addinol High Star SAE 5W-40
Adnoc Adnoc Image SAE 5W-40
Agip Agip 7004 SAE 5W-40
Agip Agip Extra HTS SAE 5W-40
Agip Agip Formula Prestige SAE 5W-40
Agip Agip Sint Evolution SAE 5W-40
Agip Agip Sint Turbo Diesel Evolution SAE 5W-40
Agip Agip Synthetic PC SAE 5W-40
Agip Agip Tecsint SAE 5w30
Agip Agip Tecsint SL SAE 5W-40
Aral Aral High Tronic SAE 5W-40
Aral Aral P 426 SAE 0W-40
Aral Aral SuperSynthetic SAE 0W-40
Aral Aral SuperTronic SAE 0W-40
Aral Aral SuperTronic Diesel SAE 0W-40
Aral Aral SuperTronic G SAE 0W-30
Aral Aral Tronic 431 SAE 5W-40
Armorine Armorine Couguar SAE 5W-40
Auto-Teile-Ring Cartechnic Motorenöl SAE 5W-40
Auto-Teile-Ring Cartechnic Motorenöl MS SAE 5w30
Avia Avia Synthetic SAE 5W-40
Beijing Tongyi Petroleum Xin Gai Nian SAE 5W-40
Blu Lubricants Inc Blu Synthetic - Technician Series FS SAE 5w30
BP BP EuroSpirit SAE 5W-40
BP BP Professional EURO Plus SAE 5W-40
BP BP Visco 5000 SAE 5W-40
BP BP Visco 5000 C SAE 5W-40
BP BP Visco 5000 Turbo Diesel SAE 5W-40
BP BP Visco 7000 SAE 0W-40
BP BP Visco 7000 M SAE 0W-30
BP BP Visco 7000 Sport SAE 5W-40
BP BP Visco 7000 Turbo Diesel SAE 0W-40
BP BP Visco 7000 Turbo Diesel Sport SAE 5W-40
BP BP Visco 7000M SAE 0W-30
publication.
Page 2 of 10 3/6/09
BP BP Visco Special V SAE 5W-40
Bucher AG MOTOREX PROFILE V-XL SAE 5W-40
Bucher AG MOTOREX Select SP-X SAE 5w30
Car Jack Car Jack GPD SAE 5W-40
Carat ad-Diesel PD Oil SAE 5W-40
Carat ad-Synt Oil SAE 5W-40
Castrol DCO Top Up SAE 0W-30
Castrol Edge SAE 0W-30
Castrol Edge SAE 5W-40
Castrol Edge SAE 0W-40
Castrol Edge Sport SAE 0W-40
Castrol Edge Turbo Diesel SAE 5W-40
Castrol Edge Turbo Diesel SAE 0W-30
Castrol Formula SLX Long Tec Turbo Diesel SAE 0W-30
Castrol GTX 9 Magnatec SAE 5w30
Castrol GTX Magnatec SAE 5w30
Castrol GTX Magnatec C3 SAE 5w30
Castrol Magnatec SAE 5w30
Castrol Magnatec C3 SAE 5w30
Castrol Magnatec C3 SAE 5W-40
Castrol Magnatec Diesel B4 SAE 5W-40
Castrol Magnatec Diesel C3 SAE 5W-40
Castrol Magnatec Professional B4 SAE 5W-40
Castrol Magnatec Professional C3 SAE 5w30
Castrol Magnatec Professional C3 SAE 5W-40
Castrol SLX SAE 0W-30
Castrol SLX 505 01 SAE 5W-40
Castrol SLX Longtec SAE 0W-30
Castrol SLX Professional SAE 5W-40
Castrol SLX Professional 505 01 SAE 5W-40
Castrol SLX Professional B4 SAE 5w30
Castrol SLX Professional C3 SAE 5w30
Castrol SLX Professional C3 TD SAE 0W-30
Castrol SLX Professional Longtec SAE 0W-30
Castrol SLX Professional Powerflow SAE 0W-30
Castrol SLX Professional Powerflow C3 SAE 0W-30
publication.
Page 3 of 10 3/6/09
Castrol TXT Softec SAE 5W-40
Castrol Edge Formula RS SAE 0W-40
Chevron Havoline Synthetic DS SAE 0W-30
Cyclon Hellas Cyclon F1 Racing SAE 5W-40
Delek Delkol Motorsynth FE SAE 5w30
Duckhams Duckhams Q Fully Synthetic SAE 5W-40
Duckhams Duckhams QS Premium MO SAE 5W-40
Elf Elf Excellium C3 SAE 5w30
Elf Elf Excellium DID SAE 5W-40
Elf Elf Excellium DID SAE 5w30
Elf Elf Excellium Full tech SAE 0W-30
Elf Elf Excellium SAE 0W-30
Engen Petroleum Engen Formula 505.01 SAE 5W-40
Engen Petroleum Engen Xtreme SAE 5W-40
Enoc Enoc Protec X-treme SAE 5W-40
Esso Esso 50501 SAE 5w30
Esso Esso Megatron SAE 5W-40
Esso Esso Ultron SAE 5W-40
Esso Esso Ultron Turbo Diesel SAE 5W-40
Eurol Eurol Super Lite SAE 5W-40
Eurol Eurol Turbo DI SAE 5W-40
Eurol XADO SL/CF SAE 5W-40
FAW-Sihuan Petrofer Huan Lu SAE 5W-40
Fina Fina First 500 SAE 5w30
Fina Fina First 600 SAE 0W-30
FL Selenia Selenia Aktual Fully Synthetic SAE 5W-40
FL Selenia Selenia Benzina Multi Valves Generation SAE 5W-40
FL Selenia Selenia Diesel Common Rail Generation SAE 5W-40
FL Selenia Selenia DIGITECH SAE 0W-30
FL Selenia Selenia K SAE 5W-40
FL Selenia Selenia K Pure Energy SAE 5W-40
FL Selenia Selenia Multipower C3 SAE 5w30
FL Selenia Selenia WR SAE 5W-40
Fuchs Fuchs TITAN GT1 SAE 5w30
Fuchs Fuchs TITAN Supersyn SAE 0W-30
publication.
Page 4 of 10 3/6/09
Fuchs Fuchs TITAN Supersyn LONGLIFE SAE 5w30
Galp energia Galp Energy Plus SAE 5W-40
Galp energia Galp Energy Ultra LS SAE 5W-40
Galp energia Galp Formula 1 Plus SAE 5W-40
Galp energia Galp Formula 505 SAE 5W-40
Galp energia Galp Formula TD Plus SAE 5W-40
GEMA Formula SAE 10W-40
GEMA Formula S SAE 5W-40
Ginouves York 848 SAE 5W-40
Ginouves York 948 SAE 5w30
Gulf Oil Gulf Formula ULE SAE 5w30
Igol Igol Process 505.01 SAE 5W-40
Igol Igol Process Compact M SAE 5w30
Igol Igol Profive 505.01 SAE 5W-40
Igol Igol Profive Gold SAE 5W-40
Igol Igol Profive Silver SAE 5w30
INA INA Millennium SAE 5W-40
IP IP SINTIAX 505 EXCLUSIV SAE 5W-40
Jet Jet Top Level SAE 0W-40
Kuttenkeuler Sorotec Pdi SAE 5W-40
Kuwait Petroleum Q8 Formula Excel SAE 5W-40
Liqui Moly Liqui Moly Leichtlauf Special LL SAE 5w30
Liqui Moly Liqui Moly Longtime High Tech SAE 5w30
Liqui Moly Liqui Moly Pro-Engine M 300 SAE 5w30
Liqui Moly Liqui Moly Pro-Engine M 500 SAE 5w30
Lotos Lotos Economic SL/CF SAE 5w30
Lotos Lotos Syntetic SL/SJ/CF/CD SAE 5W-40
Lotos Lotos Traffic Diesel 505.01 SAE 5W-40
Lotos Lotos Traffic Thermal Control SL/CF SAE 5W-40
Lotos Lotos Traffic Turbodiesel CF SAE 5W-40
publication.
Page 5 of 10 3/6/09
Lukoil Lukoil Synthetic SAE 5W-40
Meguin megol Motorenoel New Generation SAE 5w30
Meguin megol Motorenoel Power Synt SAE 10W-40
Meguin megol Motorenoel Super Leichtlauf Multisynth SAE 0W-30
Meguin megol Motorenoel Ultra Performance Longlife SAE 5W-40
Meguin megol Motorenoil Quality SAE 5w30
Meguin Motorenoel Ultra Performance Longlife SAE 5W-40
Meister-Öl Meister-Öl Leichtlauf-Motorenöl SAE 5W-40
Meister-Öl Meister-Öl Super Leichtlauf-Motorenöl SAE 5W-40
Mobil Mobil 1 SAE 5W-40
Mobil Mobil 1 New Life SAE 0W-40
Mobil Mobil 1 New Life Turbo Diesel SAE 0W-40
Mobil Mobil 1 Turbo Diesel SAE 0W-40
Mobil Mobil 1 Turbo Diesel SAE 5W-40
Mobil Mobil Motor Oil Plus SAE 5W-40
Mobil Mobil Special X SAE 5W-40
Mobil Mobil Super 3000 X1 SAE 5W-40
Mobil Mobil Synt S SAE 5W-40
Mobil Mobil Syst S ESP SAE 5w30
Mobil Mobil 1 Arctic SAE 0W-40
Mobil Mobil 1 Formula C SAE 0W-40
Mobil Mobil Formula X2 SAE 5W-40
Mobil Mobil Super 3000 X2 SAE 5W-40
Mobil Mobil Super 3000 X2 Turbo Diesel SAE 5W-40
Mobil Mobil Synt S Turbo Diesel SAE 5W-40
Modrica Optima Eco SAE 5w30
MOL MOL Dynamic Gold SAE 5w30
MOL MOL Dynamic Max SAE 10W-40
MOL MOL Dynamic Prima SAE 5W-40
Motul Motul 8100 X-max SAE 5w30
Motul Motul Specific 505 01 502 00 505 01 SAE 5W-40
Motul Motul Synergie SAE 5W-40
MRD Motor Gold Highline SAE 0W-30
publication.
Page 6 of 10 3/6/09
MRD Motor Gold Supertec SAE 5W-40
Neste Oil Neste City Pro SAE 5W-40
NIS Oil Refinery Beograd Galax Sint 502 SAE 10W-40
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5w30
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-40
Oel-Brack Midland Synova SAE 5W-40
Oel-Brack Midland Synqron SAE 5W-40
Oest Oest Gigant LS Plus SAE 5w30
Ölwerke Julius Schindler OJS Econo Veritas XL-HC SAE 5W-40
Ölwerke Julius Schindler OJS Econo-Veritas OM Extra SAE 0W-30
Ölwerke Julius Schindler OJS Econo-Veritas XV SAE 5W-40
Ölwerke Julius Schindler OJS Engine Oil SAE 5W-40
Ölwerke Julius Schindler OJS Meister-Öl Premium-Motorenöl SAE 0W-40
Ölwerke Julius Schindler OJS Platinum Vollsynthese SAE 0W-40
Ölwerke Julius Schindler OJS Veritas Syntolube SAE 0W-40
OMV OMV BIXXOL extra SAE 10W-40
OMV OMV BIXXOL extra Diesel SAE 10W-40
OMV OMV BIXXOL premium SAE 5W-40
OMV OMV BIXXOL premium Diesel SAE 5W-40
OMV OMV BIXXOL special C3 SAE 5w30
OMV OMV BIXXOL special G SAE 5w30
OMV OMV control light SAE 10W-40
OMV OMV syn com SAE 5W-40 SAE 5W-40
Orlen Oil Orlen Platinum MaxEnergy Euro 4 SAE 5w30
Orlen Oil Orlen Platinum Vollsynthese SAE 0W-40
Paramo Mogul Extreme SAE 5W-40
Paz Lubricants &
Chemicals Ltd Top Paz SAE 5W-40
Pennzoil Platinum European Formula SAE 5W-40
Pennzoil Platinum European Formula Ultra SAE 5w30
Pennzoil Platinum European Ultra Diesel SAE 5w30
Pentosin Pento High Performance SAE 5w30
Petro China Kunlun Tianrun SAE 5W-40
Petro China Kunlun Tianyuan SM SAE 5W-40
Profi-Tech Profi-Car Synthetic Tech XT SAE 5W-40
PTT Public Company
Limited Performa Euro Syn SAE 5W-40
publication.
Page 7 of 10 3/6/09
Quaker State Q European Engine Ultra SAE 5W-40
Quaker State Q European Engine Ultra SAE 5w30
Quaker State Q Synquest SAE 5W-40
Quantum Quantum PD Diesel SAE 5W-40
Quantum Quantum Synta ED SAE 0W-30
Quantum Quantum Synta Gold SAE 5W-40
Rafinerija Modrica Galax Racing SAE 5W-40
Raloy Raloy Genuine Engine Oil SAE 5W-40
Ravenol Ravenol Hydrocrack Synthetic. HCS SAE 5W-40
Ravenol Ravenol Super Synthetic SSO SAE 0W-30
Ravenol Ravenol VPD SAE 5W-40
Ravenol Ravenol VSI SAE 5W-40
real real,- Quality GSR SAE 5w30
real real,- Quality GPD SAE 5W-40
Repsol Repsol Elite 50501 TDI SAE 5W-40
Repsol Repsol Elite Competicion SAE 5W-40
Repsol Repsol Elite Multivalvulas SAE 10W-40
Rothen Oil Rothen Extrasynth SAE 5w30
Rowe Rowe Hightec Synthetic RS 5W-40i SAE 5W-40
Rowe Rowe Synt - HC SAE 5W-40
Rowe Rowe Synt PD SAE 5W-40
Rowe Rowe Synt RS DLS SAE 5w30
Rowe Rowe Synt RS HC-FE SAE 5w30
Shanghai Lizhong LUHU SAE 5W-40
Shanghai Tempo
Petrochem Tempo 8000-1C SAE 5W-40
Shell PKW Motorenöl SAE 5W-40
Shell Shell Helix Diesel HX7 C SAE 5W-40
Shell Shell Helix Diesel Plus SAE 5w30
Shell Shell Helix Diesel Plus SAE 5W-40
Shell Shell Helix Diesel Plus VA SAE 5w30
Shell Shell Helix Diesel Ultra SAE 0W-40
Shell Shell Helix Diesel Ultra SAE 5w30
Shell Shell Helix Diesel Ultra SAE 5W-40
Shell Shell Helix Diesel Ultra E SAE 5w30
Shell Shell Helix Diesel Ultra VA SAE 5w30
Shell Shell Helix HX7 SAE 5w30
Shell Shell Helix HX7 SAE 5W-40
Shell Shell Helix HX7 C SAE 5W-40
publication.
Page 8 of 10 3/6/09
Shell Shell Helix Plus SAE 5W-40
Shell Shell Helix Plus SAE 10W-40
Shell Shell Helix Plus SAE 5w30
Shell Shell Helix Plus AR SAE 10W-40
Shell Shell Helix Plus Extra SAE 5W-40
Shell Shell Helix Plus S SAE 5w30
Shell Shell Helix Plus S SAE 5W-40
Shell Shell Helix Plus SM SAE 5W-40
Shell Shell Helix Plus SM SAE 5w30
Shell Shell Helix Plus VB SAE 10W-40
Shell Shell Helix Premium SAE 5W-40
Shell Shell Helix Ultec SAE 0W-40
Shell Shell Helix Ultra SAE 0W-40
Shell Shell Helix Ultra SAE 5w30
Shell Shell Helix Ultra AM SAE 5w30
Shell Shell Helix Ultra AM SAE 5W-40
Shell Shell Helix Ultra C SAE 0W-40
Shell Shell Helix Ultra E SAE 5w30
Shell Shell Helix Ultra Extra Polar SAE 0W-40
Shell Shell PKW Motorenöl SAE 5W-40
Singapore Petroleum SPC Syn Ace API SM/CF SAE 5W-40
Sinopec Polar Star III SAE 5W-40
Sinopec Ultra Gold SAE 5W-40
S-Oil Corporation SSU EURO XT SAE 5W-40
S-Oil Corporation SSU EURO XT SAE 5w30
Sonol Sonol Synt 502.00 SAE 5W-40
SRS SRS ViVA 1 longlife SAE 5w30
SRS SRS ViVA 1 topsynth SAE 5W-40
SRS SRS ViVA 1 topsynth alpha SAE 5w30
SRS SRS ViVA 1 topsynth alpha LA SAE 5w30
Startol Startol Rasanta Specialsynth Pdi SAE 5W-40
Statoil Statoil LazerWay SAE 5W-40
Statoil Statoil LazerWay TDI SAE 5W-40
Statoil Statoil PRO Synthetic SAE 5W-40
Sunlight Sunlight Fullypower F-1A SAE 5W-40
SWD Concep-Tech HDC SAE 5W-40
publication.
Page 9 of 10 3/6/09
SWD GECCO Motorenöl HC SAE 5W-40
SWD swd PRIMUS DX SAE 5w30
SWD swd Primus HDC SAE 5W-40
TACTI Corporation Castle Euaro 502 SAE 5W-40
Tamoil Tamoil SINT FUTURE EXTRA SAE 5W-40
Tamoil Tamoil SINT FUTURE RACING SAE 5W-40
Tecar Tecar 50501 SAE 5w30
Tecar Tecar Leichtlaufmotorenoel SAE 5W-40
Tecar Tecar Motorenoel 505 01 SAE 5w30
Tecar Tecar Supersyn SAE 5W-40
Tedex Tedex Synthetic Motor Oil SAE 5W-40
TNK Lubricant LLC TNK Magnum Synthetic SAE 5W-40
Total Total Activa 9000 SAE 5W-40
Total Total Activa Diesel 9000 SAE 5W-40
Total Total Activa Energy 9000 SAE 0W-30
Total Total Quartz 9000 SAE 5W-40
Total Total Quartz 9000 Energy SAE 5W-40
Total Total Quartz 9000 Energy SAE 0W-30
Unil Opal Opaljet 24 S SAE 5W-40
United Oil United 1 Fully Synthetic SAE 5W-40
Valvoline Valvoline SynPower SAE 5w30
Valvoline Valvoline SynPower MST SAE 5W-40
VAPS VAPSOIL 502 00 SAE 5W-40
VAPS VAPSOIL 505 01 SAE 5w30
Vial Oil Consol Ultima SAE 5W-40
Vic-Hung ONEWAY SAE 5W-40
Volkswagen Original Teile
® Volkswagen Special plus SAE 5W-40
Weco Weco TXI Syntolube SAE 5W-40
Westfalen AG Westfalen Gigatron SAE 0W-40
Westfalen AG Westfalen Mega Tron SAE 5W-40
Wolf Wolf Masterlube Synflow DC SAE 5W-40
Wolf Wolf Masterlube Synflow PI SAE 5W-40
Würth Triathlon Formula LL SAE 5w30
Würth Triathlon Performance SAE 5W-40
Würth Triathlon Special PD SAE 5W-40
Yacco Yacco VX 1703 FAP SAE 5W-40
Yacco Yacco VX 1703 FAP SAE 5w30
Yacco Yacco VX 600 SAE 5W-40
Zeller+Gmelin Divinol Syntheticolight SAE 5W-40
publication.
Page 10 of 10 3/6/09
