VW OIL Conversation
As others have said, if it meets VW 502 spec, it is ok to use. It does not have to be 5w30 or 5w40, the spec is the important factor. For instance, under the hood of my GLI is a sticker that says to use only oil that meets the VW 502 spec.
I've been driving VW for almost 10 years, my last VW was a 2004 Passat 1.8T with over 130k miles. I never had oil issues (including sludge), always used oil that met the VW 502 spec. The car will not explode at 90-100k miles. Keep it maintained properly, and it will last. It just happens to be a little pickier on when maintenance is done, but I'd rather have one than a Honda or Toyota.
Originally Posted By: Oldmoparguy1
That was hilarious!!
I think I see your problem, Its a VW.....
As if other manufacturers didn't have specific grade and/or spec requirements.
Absolutely. There are several makes/models that I wouldn't buy, even to use as a clapped out beater. I have personal experience with a 2000 Passant. Great power train, great handling, by 2006 at 90K the suspension was toast, tie rods were about to fall off, the PS pump exploded, literally. It cost $1300 just to get it safe to drive home, ~185mi. Many other issues, car was a first new car for my son and was carefully maintained. It was a money pit. At 120K he traded it for a Honda hybrid. He got lucky, someone did him a favor and totaled it for him. Now he has a wife, two kids, and drives a really nice 2005 Corolla. Live and learn.
Wayne
Well, we all have our priorities.
I find Corollas very dangerous personally because they put me to sleep.
Originally Posted By: FowVay
Even still, the owner's manually specifically states:
"Always use an approved oil that meets Volkswagen oil quality standard VW 502.00 (gasoline engine)..."
If viscosity grade 5W-40 or 5W-30 is not available in your area, be sure to use a viscosity grade suitable for the climate, season and operating conditions that exist where the vehicle is operated. Make sure the oil meets the quality standard listed above."
This is verbatim from the owner's manual. Not much left open to interpretation if you ask me.
Good point. Based on this, personally I'd have no problem using 0w-40 or 0w-30 oil that meets VW 502.00 spec.
Wayne
Last week I saw Passat 2003 with 340K, original turbo etc.
Maybe culprit is in driver
Wayne
VWs with high miles are commonplace in Europe. I suspect that either;
VWoA markets a substandard product
Or
Most Americans fail to properly maintain their vehicles
Wayne
There are more than a few Passats over at PassatWorld with more than 250k miles. I traded mine at 130k miles (or so) and it was needing some things, but still very reliable and driveable. Last year I took a job further from home and had less time to do the work myself, and don't trust many people to do the work for me. I traded while I could still get a decent amount of money for it ($4k) for a new GLI. Looking back, I probably should've kept the Passat, but I honestly just wanted something different. The older Passats take some work to make them last, but they are good cars.
I traded my B5.5 1.8T with 128K because it needed new axels in front. Looking back, probably I suppose to keep the car, replace axels, but I just got bored with the car.
It looked like it had 28K not 128K.
The story becomes more convoluted. I just got an email from VW stating that the list I was given was out of date and I should go with a new list (attached to the email). The new list is much shorter. I think the first list they sent me was the world wide list, and the second is the US list. Interestingly, I can find no current list of the 502.00 approved oils online, anywhere. Including the VW website. Anyway, here is the list she sent:
Technical Bulletin
Page 1 of 3 plus attachment
© 2014 Volkswagen Group of America, Inc.
All rights reserved. Information contained in this document is based on the latest information available at the time of printing and is subject to the copyright and other
intellectual property rights of Volkswagen Group of America, Inc., its affiliated companies and its licensors. All rights are reserved to make changes at any time without notice.
No part of this document may be reproduced, stored in a retrieval system, or transmitted in any form or by any means, electronic, mechanical, photocopying, recording, or
otherwise, nor may these materials be modified or reposted to other sites, without the prior expressed written permission of the publisher.
Model(s) Year Eng. Code Trans. Code VIN Range
From VIN Range To
All
(except
Routan)
1997-2015 All All All All
Condition
17 14 04 September 2, 2014 2012855 Supersedes Technical Bulletin V171205 dated December 5, 2012 due to
additional model year applicability and updated oil standard lists to current specifications.
Engine Oils Which Meet Volkswagen Oil Quality Standard VW 502 00/505 00/505 01 and VW 504 00/507 00
(U.S. ONLY)
Technical Background
Information only.
Production Solution
No production change required.
Technical Bulletin
Page 2 of 3 plus attachment
Service
See attachment for a list of the “Worldwide” engine oils which currently meet Volkswagen Oil Quality Standard VW
502 00/505 00/505 01 and VW 504 00/507 00.
Quick Reference Guide
Gasoline Engines + Hybrid VW Standard
All engines VW 502 00 / 505 00 / 505 01
Diesel Engines VW Standard
Pumpe-Düse VW 505 01 or 507 00
Common-Rail, with Diesel Particulate Filter VW 507 00
Tip:
SOME ENGINE OILS LISTED ON THE ATTACHMENT MAY NOT BE AVAILABLE IN NORTH AMERICA.
Please refer to the specific Vehicle Owner’s Manual, published Technical Bulletins and Fluid Capacity Charts to
select the appropriate oil required for each Volkswagen vehicle.
The sample list attached are products generally available in the North American market that meet the
Volkswagen Oil Quality Standard VW 502 00/505 00/505 01 and VW 504 00/507 00 specification at the time
of this publication.
Technical Bulletin
Page 3 of 3 plus attachment
Warranty
Information only.
Required Parts and Tools
No Special Parts required.
No Special Tools required.
Additional Information
All part and service references provided in this Technical Bulletin are subject to change and/or removal.
Always check with your Parts Dept. and Repair Manuals for the latest information.
Firma Bezeichnung SAE-Klasse VW-Norm(en)
AD Parts AD MDXs SAE 5W-40 50200/50500/50501
Adamol Multitop PDI SAE 5W-40 50200/50500/50501
Additive Products ad-Diesel PD Oil SAE 5W-40 50200/50500/50501
Adnoc Voyger Gold SAE 5W-40 50200/50500/50501
Aral BlueTronic SAE 10W-40 50200/50500/50501
Aral HighTronic SAE 5W-40 50200/50500/50501
Aral MegaSynth SAE 5W-40 50200/50500/50501
Aral Plus2Synth SAE 10W-40 50200/50500/50501
Aral Tronic 431 SAE 5W-40 50200/50500/50501
Ardeca Syn-Tec XL SAE 5W-40 50200/50500/50501
Avia Diesel Turbo CFE SAE 10W-40 50200/50500/50501
Avia Turbo CFE SAE 10W-40 50200/50500/50501
BG Products BG Synthetic Engine Oil SAE 5W-30 50200/50500/50501
BP Visco 3000 A3/B4 SAE 10W-40 50200/50500/50501
BP Visco 3000 Diesel SAE 10W-40 50200/50500/50501
BP Visco 5000 SAE 10W-40 50200/50500/50501
BP Visco 5000 C SAE 5W-40 50200/50500/50501
Cartechnic Motorenöl MF SAE 5W-30 50200/50500/50501
Cartechnic Motorenöl Pumpe-Düse SAE 5W-40 50200/50500/50501
Castrol Edge SAE 5W-40 50200/50500/50501
Castrol Edge C3 SAE 5W-30 50200/50500/50501
Castrol Edge Professional 505 01 SAE 5W-40 50200/50500/50501
Castrol Edge Professional C3 SAE 5W-40 50200/50500/50501
Castrol Edge Turbo Diesel SAE 5W-40 50200/50500/50501
Castrol GTX A3/B3 SAE 10W-40 50200/50500/50501
Castrol GTX A3/B4 SAE 10W-40 50200/50500/50501
Castrol Magnatec C3 SAE 5W-40 50200/50500/50501
Castrol Magnatec Diesel DPF SAE 5W-40 50200/50500/50501
Castrol Magnatec Professional C3 SAE 5W-40 50200/50500/50501
Castrol Magnatec Professional Diesel SAE 5W-40 50200/50500/50501
Castrol Magnatec Professional OE SAE 5W-40 50200/50500/50501
Castrol Edge Professional OE SAE 5W-30 50200/50500/50501
Castrol Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Magnatec Professional MP SAE 5W-30 50200/50500/50501
Cepsa Xtar 505.01 SAE 5W-40 50200/50500/50501
Cepsa Xtar TDI SAE 5W-40 50200/50500/50501
Champion New Energy PI SAE 5W-40 50200/50500/50501
Champion OEM Specific C3 SAE 5W-30 50200/50500/50501
Chanchung Delian Chemical DLEO-B001 SAE 5W-40 50200/50500/50501
Cofran Sintolux DI SAE 5W-40 50200/50500/50501
Copton Formula Super SM SAE 5W-40 50200/50500/50501
Cyclon F1 TDi SAE 5W-30 50200/50500/50501
De Oliebron Tor Specialsynth NF SAE 5W-30 50200/50500/50501
Delek Delkol Motorsynth TDI SAE 5W-40 50200/50500/50501
Divinol Syntholight HC-FE SAE 5W-30 50200/50500/50501
Duglas Oil GTx Clean C3 SAE 5W-40 50200/50500/50501
Durand Isotech Hi-Tech SAE 5W-40 50200/50500/50501
Edeka Edeka Gut & Günstig Motorenöl SAE 5W-40 50200/50500/50501
Elf Competition ST SAE 15W-50 50200/50500/50501
Elf Evolution 700 ST SAE 15W-50 50200/50500/50501
ELF Evolution 900 DID SAE 5W-30 50200/50500/50501
ELF Evolution Full-Tech C3 SAE 5W-30 50200/50500/50501
22.07.2014
ELF Evolution Full-Tech MSX SAE 5W-30 50200/50500/50501
Eneos Premium Hyper 5W-40 SAE 5W-40 50200/50500/50501
Engen Xtreme SAE 5W-40 50200/50500/50501
Eni i-Sint MS SAE 5W-40 50200/50500/50501
Eni i-Sint top MS SAE 5W-30 50200/50500/50501
Euro Car Parts Triple QX SynPlus PD FS SAE 5W-30 50200/50500/50501
Eurol Turbo DI SAE 5W-40 50200/50500/50501
Eurolub Cleantec SAE 5W-30 50200/50500/50501
FAM Krusevac Fenix Premium SAE 5W-40 50200/50500/50501
Fina First 500 SAE 5W-30 50200/50500/50501
Fuchs Titan GT1 SAE 5W-40 50200/50500/50501
Fuchs Titan GT1 Pro Flex SAE 5W-30 50200/50500/50501
Fuchs Titan GT1 Pro Gas SAE 5W-30 50200/50500/50501
Fuchs Titan GT1 Pro Gas SAE 5W-40 50200/50500/50501
Fujian Laike Laike SM SAE 5W-40 50200/50500/50501
Galp energia Active 3000 V 505 SAE 5W-40 50200/50500/50501
Galp energia ENERGY ULTRA LS SAE 5W-40 50200/50500/50501
Galp energia FORMULA 505 SAE 5W-40 50200/50500/50501
Gecco Motorenöl SY SAE 5W-40 50200/50500/50501
G-Energy Service Line GMO SAE 5W-30 50200/50500/50501
G-Energy Service Line W SAE 5W-40 50200/50500/50501
Gulf Formula CX SAE 5W-30 50200/50500/50501
Gulf Formula ULE SAE 5W-30 50200/50500/50501
Gulf Formula ULE SAE 5W-40 50200/50500/50501
Gulf Progress Extended SAE 5W-30 50200/50500/50501
INA Star SAE 5W-40 50200/50500/50501
Indian Oil Servo Technik ol Plus SAE 5W-30 50200/50500/50501
Industrial Quimica Riojana MatraX InfluX DPF C3 SAE 5W-30 50200/50500/50501
Industrial Quimica Riojana MatraX InluX 505,01 SAE 5W-40 50200/50500/50501
Interparts Autoteile GmbH Trost masteroil c-tec Power SAE 10W-40 50200/50500/50501
Jet High Level SAE 10W-40 50200/50500/50501
Jet High Level Diesel SAE 10W-40 50200/50500/50501
Jiangsu Lopal Petrochemical Sonic 9000 SAE 5W-40 50200/50500/50501
Jiangsu Lopal Tech Lopal SAE 5W-40 50200/50500/50501
Kendall GT-1 ® Full Synthetic Euro Motor Oil SAE 5W-30 50200/50500/50501
Kendall GT-1 ® Full Synthetic Euro Motor Oil SAE 5W-40 50200/50500/50501
Korlube Euro Formula Eco SAE 5W-40 50200/50500/50501
Kunlun Tianrun SM SAE 5W-40 50200/50500/50501
Kross Exeo TDI SAE 5W-40 50200/50500/50501
Kunlun Tianyuan SM/CF SAE 5W-40 50200/50500/50501
Kuttenkeuler M-Tronic Extra SAE 5W-30 50200/50500/50501
Kuttenkeuler Sorotec 2+ Pdi SAE 5W-40 50200/50500/50501
Liqui Moly Diesel High Tech SAE 5W-40 50200/50500/50501
Liqui Moly Nachfüll-Öl SAE 5W-40 50200/50500/50501
Liqui Moly Pro-Engine M 500 SAE 5W-30 50200/50500/50501
Liqui Moly Pro-Engine M400 SAE 5W-40 50200/50500/50501
Liqui Moly Top Tec 4100 SAE 5W-40 50200/50500/50501
Liqui Moly Top Tec 4600 SAE 5W-30 50200/50500/50501
Liqui Moly Top Tec 4605 SAE 5W-30 50200/50500/50501
Lotos Quazar SAE 5W-40 50200/50500/50501
Lotos Quazar C3 SAE 5W-30 50200/50500/50501
Lotos Syntetic Plus SAE 5W-40 50200/50500/50501
22.07.2014
Lotos Syntetic Plus Turbodiesel SAE 5W-40 50200/50500/50501
Lotos Traffic Pro 505.01 SAE 5W-40 50200/50500/50501
Lotos Traffic Pro 505.01 C3 SAE 5W-30 50200/50500/50501
Lukoil Genesis Premium SAE 5W-40 50200/50500/50501
MAPO Super PDI SAE 5W-40 50200/50500/50501
Meguin megol Motorenoel Efficiency SAE 5W-30 50200/50500/50501
Metro Cash and Carry Biloxxi HC SAE 5W-40 50200/50500/50501
Mexicana Lubricants Akron Spitzen SN SAE 5W-40 50200/50500/50501
Midland Synova SAE 5W-40 50200/50500/50501
Minerva Oil TSH SAE 5W-40 50200/50500/50501
Mobil Super 3000 Formula G SAE 5W-30 50200/50500/50501
Mobil Super 3000 XE SAE 5W-30 50200/50500/50501
Mobil Syst S Special V SAE 5W-30 50200/50500/50501
Modrica Optima 505.01 SAE 5W-40 50200/50500/50501
Modrica Optima ECO SAE 5W-30 50200/50500/50501
Mol Dynamic Prima SAE 5W-40 50200/50500/50501
Motorex Profile V-XL SAE 5W-40 50200/50500/50501
Motorex Select LA-X SAE 5W-30 50200/50500/50501
Motorex Select SP-X SAE 5W-40 50200/50500/50501
Motul 8100 X-clean SAE 5W-40 50200/50500/50501
Motul 8100 X-clean FE SAE 5W-30 50200/50500/50501
Motul Feu Vert 505 01 SAE 5W-40 50200/50500/50501
Motul Feu Vert Multi Normes SAE 5W-40 50200/50500/50501
Motul Specific 50200 50501 SAE 5W-40 50200/50500/50501
Müller Mineralöle Synt 2+ Pdi SAE 5W-40 50200/50500/50501
Neste City Standard SAE 5W-40 50200/50500/50501
Oest GIGANT LS PLUS SAE 5W-30 50200/50500/50501
Orlen Oil star tron LL SAE 10W-40 50200/50500/50501
Paz Lubricants & Chemicals Ltd Top Paz SAE 5W-40 50200/50500/50501
Pentosin Pento High Performance II SAE 5W-40 50200/50500/50501
Pentosin Pentosynth HC SAE 5W-40 50200/50500/50501
PetroChina Kunlun Tianrun 9000 C3 SAE 5W-30 50200/50500/50501
PetroChina Kunlun Tianrun 9000 SM SAE 5W-40 50200/50500/50501
Petronas Syntium 3000 AV SAE 5W-40 50200/50500/50501
Petronas TD 6412019 SAE 5W-40 50200/50500/50501
Phi Oil GmbH Specialsynth Gold SAE 5W-40 50200/50500/50501
Pinnacle Oil National Synthetic SAE 5W-40 50200/50500/50501
Platinum MaxExpert C3 SAE 5W-40 50200/50500/50501
Platinum PRO C3 SAE 5W-40 50200/50500/50501
PT Biru Megah Abadi BMI Gold Series SAE 5W-30 50200/50500/50501
PTT Performa Euro Syn SAE 5W-40 50200/50500/50501
Quantum Platinum SAE 5W-40 50200/50500/50501
Quantum Synta SAE 10W-40 50200/50500/50501
Raloy Full Synthetic Engine Oil SAE 5W-40 50200/50500/50501
Raloy Genuine Engine Oil SAE 5W-40 50200/50500/50501
Ravenol VMO SAE 5W-40 50200/50500/50501
Ravenol VPD SAE 5W-40 50200/50500/50501
real,- Quality GPD SAE 5W-40 50200/50500/50501
Redoil Italia Challoils SAE 5W-40 50200/50500/50501
Repsol Elite 50501 TDI SAE 5W-40 50200/50500/50501
Repsol Elite Evolution SAE 5W-40 50200/50500/50501
Repsol Elite Evolution Long Life SAE 5W-30 50200/50500/50501
Rheinol Primus DX SAE 5W-30 50200/50500/50501
22.07.2014
Rheinol Primus DXM SAE 5W-40 50200/50500/50501
Rosneft Premium SAE 5W-40 50200/50500/50501
Rowe Hightec Synt RS DLS SAE 5W-30 50200/50500/50501
Rowe Multi Formula SAE 5W-40 50200/50500/50501
Rowe Synt RS-DLS SAE 5W-30 50200/50500/50501
Shanghai Lizhong LUHU SAE 5W-40 50200/50500/50501
Shanghai Tempo Petrochem Tempo 8000-3 SAE 5W-40 50200/50500/50501
Shell Helix Diesel HX7 AV SAE 5W-30 50200/50500/50501
Shell Helix HX7 Professional AV SAE 5W-30 50200/50500/50501
Shell Helix Ultra SAE 5W-40 50200/50500/50501
Shell PC 1112 SAE 5W-40 50200/50500/50501
Sinopec Justar J500 SAE 5W-40 50200/50500/50501
Sinopec Polar Star III SAE 5W-40 50200/50500/50501
Sonol SYNT 505.01 SAE 5W-40 50200/50500/50501
SRS ViVA 1 topsynth alpha LA SAE 5W-30 50200/50500/50501
Startol Vita Extra SAE 5W-30 50200/50500/50501
Sunlight Lubrication Fullypower SAE 5W-40 50200/50500/50501
SWD Concep-Tech DX SAE 5W-30 50200/50500/50501
SWD CONCEP-TECH Synth. SAE 5W-40 50200/50500/50501
SWD Gecco MZB SAE 5W-30 50200/50500/50501
Tamoil Sint Future Extra SAE 5W-40 50200/50500/50501
Tamoil Sint Future KW SAE 10W-40 50200/50500/50501
Tecar Leichtlauf Motorenöl SAE 5W-40 50200/50500/50501
Tecar Motorenoel 505 01 SAE 5W-30 50200/50500/50501
Tecar Special DX2 SAE 5W-30 50200/50500/50501
Tedex Synthetic Motor Oil SAE 5W-40 50200/50500/50501
Texaco Havoline Ultra S SAE 5W-40 50200/50500/50501
Thevenin & Ducrot Avia Synth SAE 5W-40 50200/50500/50501
Total Activa Diesel 7000 SAE 15W-50 50200/50500/50501
Total Quartz 4x4 SAE 15W-50 50200/50500/50501
Total Quartz 7000 SAE 15W-50 50200/50500/50501
Total Quartz 9000 DID SAE 5W-30 50200/50500/50501
Total Quartz Energy 7000 SAE 15W-50 50200/50500/50501
Total Quartz INEO MC3 SAE 5W-30 50200/50500/50501
Unil Opal Opaljet Futura SAE 5W-40 50200/50500/50501
Unil Opal Opaljet Longlife 3 SAE 5W-30 50200/50500/50501
Valvoline DuraBlend Diesel SAE 5W-40 50200/50500/50501
Valvoline SynPower motor oil SAE 5W-40 50200/50500/50501
Valvoline SynPower MST SAE 5W-40 50200/50500/50501
Valvoline SynPower MST C3 SAE 5W-40 50200/50500/50501
Veedol Powertron Ultra SAE 5W-30 50200/50500/50501
Veedol Syntron C3 SAE 5W-30 50200/50500/50501
Volkswagen Original Teile® Special Plus SAE 5W-40 50200/50500/50501
Weco TXI Turbo LL SAE 10W-40 50200/50500/50501
Westfalen AG WXD SAE 10W-40 50200/50500/50501
Wolf Officialtech C3 SAE 5W-30 50200/50500/50501
Wolf Vitaltech PI SAE 5W-40 50200/50500/50501
Yacco VX 1000 FAP SAE 5W-40 50200/50500/50501
Yacco VX 1000 LL SAE 5W-40 50200/50500/50501
Yacco VX 1703 FAP SAE 5W-30 50200/50500/50501
YPF Elaion F50 SAE 5W-40 50200/50500/50501
YPF Elaion SUV SAE 5W-40 50200/50500/50501
22.07.2014
AD Parts AD SCB SAE 5W-30 50400/50700
AD Parts AD SCC SAE 5W-30 50400/50700
Adamol Multitop Longlife SAE 5W-30 50400/50700
Addinol Giga light MV 0530 LL SAE 5W-30 50400/50700
Addinol Mega Light MV 0539 LE SAE 5W-30 50400/50700
Addinol Mega Star SAE 5W-30 50400/50700
AMAG GAMAPARTS Super LongLife III SAE 5W-30 50400/50700
April April Hyper Syn Euro SAE 5W-30 50400/50700
Aral SuperTronic Longlife III SAE 5W-30 50400/50700
Ardeca Syn-Tec Pro SAE 5W-30 50400/50700
ATU Motor Oil Spezial SAE 5W-30 50400/50700
Audi Original Teile® Long Life III Hochleistungsmotorenöl SAE 5W-30 50400/50700
Avia Aviasynth LSP Plus SAE 5W-30 50400/50700
Avia avilubesynth LSP Plus SAE 5W-30 50400/50700
Avia Synth Longlife III SAE 5W-30 50400/50700
Aviaticon Unique LongLife WIV SAE 5W-30 50400/50700
Biloxxi Biloxxi III SAE 5W-30 50400/50700
Bizol Compatible SAE 5W-30 50400/50700
Blasol PXA SAE 5W-30 50400/50700
BLU Synthetic Technician Series XLS-FS SAE 5W-30 50400/50700
BP Visco 7000 SAE 5W-30 50400/50700
BP Visco 7000 Longlife III SAE 5W-30 50400/50700
Caltex Havoline Ultra V SAE 5W-30 50400/50700
Carat ad-High Tech Longlife III SAE 5W-30 50400/50700
Carat GTE Special-Edition Longlife III SAE 5W-30 50400/50700
Cartechnic Motorenöl Longlife III SAE 5W-30 50400/50700
Cartechnic Motorenöl Multi SAE 5W-30 50400/50700
Castrol Edge SAE 5W-30 50400/50700
Castrol Edge Professional LL03 SAE 5W-30 50400/50700
Castrol Edge Professional Longlife III SAE 5W-30 50400/50700
Castrol Magnatec Professional C3 SAE 5W-30 50400/50700
Castrol SLX Professional LL03 SAE 5W-30 50400/50700
Centro Motoröl Longlife III SAE 5W-30 50400/50700
Cepsa Xtar 504 507 SAE 5W-30 50400/50700
Cepsa Xtar TDI 504 507 SAE 5W-30 50400/50700
Champion OEM Specific LL III SAE 5W-30 50400/50700
Champion Syntolube Longlife III SAE 5W-30 50400/50700
Classic Meduna PT 530 Longlife III LA SAE 5W-30 50400/50700
Cofran Sintolux FORCE V SAE 5W-30 50400/50700
CTR MatraX InfluX V-LL SAE 5W-30 50400/50700
Cyclon Hellas F1 V SAE 5W-30 50400/50700
DBV LL SAPS Super Universal SAE 5W-30 50400/50700
De Oliebron Tor Extendo NF SAE 5W-30 50400/50700
Denicol Syn Extra Long Life III SAE 5W-30 50400/50700
Divinol Syntholight DPF SAE 5W-30 50400/50700
Elf Excellium TDI SAE 5W-30 50400/50700
Elf Solaris LLX SAE 5W-30 50400/50700
Emka Superpower C-3 SAE 5W-30 50400/50700
ENEOS Premium Ultra Fully Synthetic SAE 5W-30 50400/50700
Eni i-Sint SAE 5W-30 50400/50700
Enoc Kuwa Speed 4700 SAE 5W-30 50400/50700
Epro Meisteröl WIV Longlife SAE 5W-30 50400/50700
Eurol Syntence Fully Synthetic SAE 5W-30 50400/50700
Eurolub Eurolub WIV ECO SAE 5W-30 50400/50700
Exol Optima LSV SAE 5W-30 50400/50700
FAM Krusevac Fenix Power 504/507 SAE 5W-30 50400/50700
Fina FINA First 500 504/507 SAE 5W-30 50400/50700
Fuchs Titan GT1 LONGLIFE III SAE 5W-30 50400/50700
Fuchs Titan GT1 PRO C-3 SAE 5W-30 50400/50700
22.07.2014
Galp energia Active 3000 V SAE 5W-30 50400/50700
Galp energia Formula Longlife III SAE 5W-30 50400/50700
G-Energy Service Line W SAE 5W-30 50400/50700
Global Racing Oil GXS SAE 5W-30 50400/50700
Globus multilub Longlife III SAE 5W-30 50400/50700
Gulf Formula GVX SAE 5W-30 50400/50700
Gulf Progress Intensia SAE 5W-30 50400/50700
HEM Longlife III SAE 5W-30 50400/50700
Igol PROFIVE 504/507 SAE 5W-30 50400/50700
Igol Profive Platinium SAE 5W-30 50400/50700
Ina Maziva Ultra Star FE SAE 5W-30 50400/50700
Interparts Autoteile GmbH Trost masteroil c-tec Power LL3 SAE 5W-30 50400/50700
JB German Oil Longlife WIV 1 Plus SAE 5W-30 50400/50700
Kaufland K-Classic Motorenöl Longlife III SAE 5W-30 50400/50700
Kendall Elite Longlife III SAE 5W-30 50400/50700
KLOBOmotive KLOBOlube Longlife III SAE 5W-30 50400/50700
Kompressol MBV SAE 5W-30 50400/50700
Kross Exeo LL SAE 5W-30 50400/50700
Kuttenkeuler Ultra Tronic SAE 5W-30 50400/50700
Liqui Moly Pro-Engine M600 SAE 5W-30 50400/50700
Liqui Moly Top Tec 4200 SAE 5W-30 50400/50700
Lotos Quazar LLIII SAE 5W-30 50400/50700
Mabanol Xenon Ultra Synth Longlife SAE 5W-30 50400/50700
Mannol Energy Combi LL SAE 5W-30 50400/50700
megol Motorenoel Compatible SAE 5W-30 50400/50700
Metro Cash and Carry Biloxxi III SAE 5W-30 50400/50700
Millers XF Longlife SAE 5W-30 50400/50700
Minerva Oil TSV SAE 5W-30 50400/50700
Mitan Alpine Longlife III SAE 5W-30 50400/50700
Mitasu Euro Diesel LongLife 100% Synthetic SAE 5W-30 50400/50700
Mobil 1 ESP Formula SAE 5W-30 50400/50700
Mobil Super 3000 Formula V SAE 5W-30 50400/50700
Mol Dynamic Gold Longlife SAE 5W-30 50400/50700
Moravia-Chem Cinol Long Life SAE 5W-30 50400/50700
Morris Multilife V-Max SAE 5W-30 50400/50700
Motorex Profile V-XL SAE 5W-30 50400/50700
Motul 8100 X-clean + SAE 5W-30 50400/50700
Motul Expert LL SAE 5W-30 50400/50700
Motul Feu Vert 504 00 507 00 SAE 5W-30 50400/50700
Motul Specific 504 00 507 00 SAE 5W-30 50400/50700
MPM MPM 05000 Motoroil premium synthetic LL III SAE 5W-30 50400/50700
New Process Eco Syn Plus SAE 5W-30 50400/50700
Nisotec Autoline W SAE 5W-30 50400/50700
Nordlub V-Kombi LL3 SAE 5W-30 50400/50700
Oest Longlife III SAE 5W-30 50400/50700
Oilfino Via Ultra LL SAE 5W-30 50400/50700
OMV BIXXOL special UP SAE 5W-30 50400/50700
OMV BIXXOL special V7 SAE 5W-30 50400/50700
Orlen Oil Platinum MaxExpert V SAE 5W-30 50400/50700
Orlen Oil Platinum PRO V SAE 5W-30 50400/50700
OWS Grandsport DPF SAE 5W-30 50400/50700
Panolin Avanis SV-X SAE 5W-30 50400/50700
Paz Extreme 507.00 SAE 5W-30 50400/50700
Pennzoil Platinum Euro L SAE 5W-30 50400/50700
Pennzoil Ultra Euro L SAE 5W-30 50400/50700
Penrite Oil Enviro+ SAE 5W-30 50400/50700
Pentosin Pento Super Performance III SAE 5W-30 50400/50700
Petrol Ofisi PO Maxima VSA SAE 5W-30 50400/50700
Petronas Syntium 5000 AV SAE 5W-30 50400/50700
Power Oil High-Tech Schmierstoffe Super Combi SAE 5W-30 50400/50700
22.07.2014
Praktiker Praktiker SAE 5W-30 50400/50700
Quaker State QS Ultimate Durability SAE 5W-30 50400/50700
Quantum Longlife III SAE 5W-30 50400/50700
Ravenol VMP SAE 5W-30 50400/50700
Ravenol WIV III SAE 5W-30 50400/50700
real,- Quality GSL SAE 5W-30 50400/50700
Repsol Elite Long Life 50700/50400 SAE 5W-30 50400/50700
Rock Oil Synthesis EXTRA-Life SAE 5W-30 50400/50700
Rowe Multi Synt DPF SAE 5W-30 50400/50700
Rymco Posidon LL-III SAE 5W-30 50400/50700
Sash Flagship C3 OEM 547 SAE 5W-30 50400/50700
SCT Pemco Longlife SAE 5W-30 50400/50700
Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700
Shell Helix Ultra AV-L SAE 5W-30 50400/50700
Shell Helix Ultra ECT SAE 5W-30 50400/50700
Shell Helix Ultra ECT Diesel SAE 5W-30 50400/50700
Shell Helix Ultra Extra SAE 5W-30 50400/50700
Shell Helix Ultra Professional AV-L SAE 5W-30 50400/50700
SK Lubricants ZIC XQ TOP SAE 5W-30 50400/50700
SLI Extra Sint APL SAE 5W-30 50400/50700
SRS ViVA 1 SLV plus SAE 5W-30 50400/50700
Startol Longlife Ultra SP 1 SAE 5W-30 50400/50700
Teboil Diamond Carat III SAE 5W-30 50400/50700
Tecar Motorenoel 504 00 / 507 00 SAE 5W-30 50400/50700
Tecar Motorenöl Spezial 50400/50700 SAE 5W-30 50400/50700
Tectrol Speed LL 530 SAE 5W-30 50400/50700
Tectrol Speed Longlife III SAE 5W-30 50400/50700
Texaco Havoline Ultra V SAE 5W-30 50400/50700
Total Activa Ineo Long Life SAE 5W-30 50400/50700
Total Quartz Ineo Long Life SAE 5W-30 50400/50700
Unil Melia 3500 SAE 5W-30 50400/50700
Unil Opal Opaljet Energy 3 SAE 5W-30 50400/50700
United Oil Gold VX SAE 5W-30 50400/50700
Valvoline SynPower XL-III SAE 5W-30 50400/50700
Valvoline SynPower XL-LLL SAE 5W-30 50400/50700
Vapsoil Vapsoil 507 00 SAE 5W-30 50400/50700
Volkswagen Original Teile® Long Life III Hochleistungsmotorenöl SAE 5W-30 50400/50700
Voltronic Motoröl MDPF SAE 5W-30 50400/50700
Wibo Wibosport Longlife III SAE 5W-30 50400/50700
Winba Oil-X 507 00 SAE 5W-30 50400/50700
Wolf Masterlube Synflow Longlife III SAE 5W-30 50400/50700
Wolf Officialtech LL III SAE 5W-30 50400/50700
Wunsch Syntholube Longlife III SAE 5W-30 50400/50700
Würth Triathlon Endurance III SAE 5W-30 50400/50700
Xado Atomic Oil 504/507 SAE 5W-30 50400/50700
Yacco Lube DE SAE 5W-30 50400/50700
22.07.2014
That list makes no sense in the US - most of these oils aren't available here.
It does not, and not because of that reason.
For example there is no Castrol 0W40 or Mobil1 0W40 which actually have much better properties at high temperatures then Castrol 5W40.
But then, on the list is Mobil1 ESP 5W30 with lower HTHS.
Anyway, there is NO WAY VW can win argument in the court that if you use Mobil1 0W40 they can void your warranty, especially because both Castrol and M1 0W40 have VW approval.
So basically, my wife's Tiguan which I still put M1 ESP 5W30 is OK but my CC (if it was under factory warranty) would not be bcs in the engine is M1 0W40.
I emailed Castrol and asked whether their 0-40 (which has the 502.00 on their label) if it was ok to use. They replied that only a special oil available from the VW dealer was good to go.
I find it peculiar that the list of approved oils is not available on the VW website, or anywhere else on line, that I could find.
I wonder if a restraint of trade violation is what is really going on?
I think a great deal of confusion is what's really going on. If it were me, and the oil were approved, I'd use it. Specifically up here, I'd be running to get the Castrol 0w-40 since that's the best deal of approved oils available (only one in 5 L jugs up here and on rollbacks on occasion).
See the list I just posted. Castrol 0-40 is not an officially approved oil.
Originally Posted By: riggaz
0W-X oils are not recommended at all, there must be a good engineering reason for it.
What would that be? Better cold start? Meeting MB 229.5 (unlike that special oil in VW dealership that meets only MB229.3 which means more deposits) so less deposits and less work for them=less money?
Castrol 0W40 is better in every category then that SPECIAL oil in dealership which is Castrol 5W40 with 13% NOACK.
Also, Castrol 0W40 is approved in Europe and carries VW 502.00 for American market.
OMG
I know the combination of viscosity AND spec level is important most of the time. When I looked this car up on my system it only gave 5w-40 502.00 as the fixed interval oil choice even though there are 10w-40's, 5w-30's and 0w-40's with the 502.00 approval.
The Mercedes 5.3 AMG engine requires 229.5 AND 0w-40/5w-40 even though there are 0w-30's with the 229.5 approval, so spec approvals are obviously not the only thing to pay attention to.
Sure, but problem here is that VW is using 5W40 in the dealership (which is IMO horrible oil) and OP (as i do too) is using 0W40.
Now I would really like to know why 5W40 is better then 0W40, especially because 0W40 has better cold cranking abilities and has same viscosity at working temps.
