Originally Posted By: fredf
Originally Posted By: Sunstealer
It is worded different in my 2011 Audi:
Viscosity:
Engine oils are graded according to their viscosity. The proper viscosity grade oil for your engine depends on climactic or seasonal conditions where you drive. You can use oil with a viscosity grade of SAE 5W40 across all temperature ranges for normal driving conditions.
However, if engine oil viscosity grade SAE 5W40 is not available, you can also use viscosity grade SAE 5w30 or SAE 0W-40 as long as it meets Audi oil quality standard VW 502 00 specifications.
On down, when mentioning about adding a non 502-approved oil if none is available, it again states:
but, even then, only in viscosity grades SAE 5W-40, SAE 5w30, or SAE 0W-40.
Maybe the higher performance engines are more particular about viscosity than others?
There they go again! They say you can use 502 oil as long as the viscosity grade is: XW-30/40 but NONE of the ones they list would include GC which, of course, is 0W-30.
So, again, while GC is a 502 oil, they muddy the waters by going on to list all acceptable grades which do NOT include GC!
I really can understand peoples' confusion.
YOU are the one confused.
No offense and I not trying to be rude but you really lack reading comprehension.
NO. YOU are twisting what was said. You are wrong. Sunstealer said his manual states the following:
His manual states you CAN use those weight.
C A N- Meaning you MAY, It is an OPTION, it is not a REQUIREMENT.
NO where does it say you must use a certain oil weight.
Sunstealer stated something along the lines that the manual gives a weight requirement When (ARE YOU READY FOR THIS)
A VW 502 speced oil IS NOT AVAILABLE!!!
There's nothing else we can do for you. The facts are black and white. YOU want there to be a grey area, but there is NONE.
