VOA MTF Volvo 645
Sweden
VOA of the MTF Volvo 645:
Strong add pack, and should be esters based with this high TAN ?
SAE 5w30 (SAE 75W) Volvo Std 1273,08 which describes
transmission oil 97308
A multigrade synthetic oil intended for manual transmissions in
passenger cars.
The oil has very good low temperature properties and enables
smooth gear changes down to -40°C.
The low friction contributes to low fuel consumption.
Recommended for transmissions up to and incl. model
year 1995; M45, M46, M47, M90, M65 6-cyl. engine, M59
(T-yellow/red special turbo), M56, M58AWD. All model years
M5M42 GDI-engine S40/V40. The oil is developed for
transmissions and has no equal on the market. The oil gives
very good shifting and low-temperature characteristics.
Technical data
Quality: API GL-4
describes transmission oil
97308
Density: 885 kg/m3
Base: Synthetic
Lowest flow point: -48°C
Flash point: +234°C/ 453°F
Viscosity at 40°C: NE
Viscosity at 100°C: 10.5 mm2/s
The iron is part of the anti-oxidant chemistry, not the container.
The boron is the low temp anti-wear, while the Phos-zinc is the high temp ZDDP anti-wear.
