Is this a product this Mobil 1 ESP that I could run in my 2017 Honda Accord 2.4 with direct injection? Are there any pros or cons to using this over a regular 0w30 or 5W30? Any advice that all help would be greatly appreciated thank you
Yes it will be great. I use it in my 2018 accord. It’s better than the AFE 0w30 and Vanilla 5w30. ESP is ACEA C3 rated and Carries the following manufacturer specsIs this a product this Mobil 1 ESP that I could run in my 2017 Honda Accord 2.4 with direct injection? Are there any pros or cons to using this over a regular 0w30 or 5W30? Any advice that all help would be greatly appreciated thank you
| MB-Approval 229.31 |
| MB 229.51 |
| MB 229.52 |
| PORSCHE C30 |
| VW 504 00 |
| VW 507 00 |
It’s not just for diesel since it’s VW 504 as well. direct injected engines do produce soot His 2.4 liter is a direct injected engine and the 1.5t in my accord is also direct injected turbo. That oil helps with the fuel shearing the oil as well.It’s essentially a diesel oil, based on the certifications. I poured some into my in-laws ML320 CDI Diesel Benz last week because it met the specifications.
It will work in the Accord but I don’t see how it will benefit your engine. It doesn’t produce loads in Soot during normal operation.![]()
Yeah - D’paint has run it in his Jeep gasser for a long time …It’s not just for diesel since it’s VW 504 as well. direct injected engines do produce soot His 2.4 liter is a direct injected engine and the 1.5t in my accord is also direct injected turbo. That oil helps with the fuel shearing the oil as well.
Holy ****...Some base oils (particularly group IV PAO) have difficulty dissolving additives in solution. Group V base oils like ANs and esters have low aniline points and high solvency which, when added to a non-polar base oil, improves the ability of the base oil blend to dissolve additives into solution and keep them in solution. In much the same way, they can dissolve carbon deposits, sludge, and varnish into solution as well, thus improving the oil's ability to clean inside the engine. They also have a positive effect on the oil's volatility, and improve the oil's shear and thermal stability at high heat. A downside is they can hurt low temperature pumpability as they tend to have low viscosity indexes of 80-100. They can also interfere with anti-wear performance if the concentration is too high.
HPL's oils contain both AN and ester. They clean better than Mobil 1 ESP and likely less volatile. Aside from the base oil, HPL employs much more top treatment with moly-based additives for better friction reduction and oxidation resistance, a higher amount of overbased detergents, and much higher starting TBN nearly double that of the Mobil 1 ESP.
What’s the HTHS of the ESP 0/30This is just a guess, however, I believe that the 31 oxidation number indicates a nice ester content. This looks like a solid choice for anyone who wants to run something different, but isn't ready to spend money on a boutique oil.
Trimer Moly to help with cam wear, and a very nice amount of Boron multifunctional additives, which also act as friction reducers. ZDDP is also somewhere in-between API SP and full-SAPS oils, though at 800ppm Phosphorus, it clearly qualifies as an API SP oil, should Mobil choose to get an API SP license for this product.
One might suppose that the deleted member was deleted.What’s the HTHS of the ESP 0/30
It will also benefit the higher HTHS and ZDDPIt’s not just for diesel since it’s VW 504 as well. direct injected engines do produce soot His 2.4 liter is a direct injected engine and the 1.5t in my accord is also direct injected turbo. That oil helps with the fuel shearing the oil as well.
It's at least 3.5 HTHS but probably not much beyond that.What’s the HTHS of the ESP 0/30
Correct.It's at least 3.5 HTHS but probably not much beyond that.
It's the whole additive package that determines a good LSPI oil. One excellent way of determining that would be to select an oil based on it's specification meeting the engine builder. You're wanting to use that Elantra with Euro oil. Mobil 1 ESP Meets SP testing so that would mean it also passed SP's latest LSPI requirements. Just looking at the Calcium alone for LSPI is not the whole story. There is a balance to the additives & one of the main alternatives is to reduce calcium & increase Magnesium (Low Calcium alone is not enough for protection). This ESP 0w30 is a Low SAPS formulation so they are reducing ash/additives for emission systems & appears to be right at the 800 PPM maximum for API SP. Although, I still think this oil would be a good option for the Hyundai you should look for an oil that includes Magnesium. What does it say about the API/ACEA specifications in the manual?What’s everyone’s opinion on the upper limit of Ca for LSPI prevention with small TGDI engines?
I was just having a conversation with someone about this on another board.
He feels that the ~ 1700 ppm of Ca in Mobil 1 ESP 30 grade is too high for small TGDI engines.
Relevant for me right now considering that the Mobil 1 ESP 0w30 is now available for nearly the same cost as other mid to upper end synthetics on the shelf at Walmart.
I’m considering getting a Hyundai Elantra N. Given that the Elantra N calls for a 0W-30, and I’m already using the Mobil 1 ESP 0w30 in our van, it would make a lot of sense to also use it in the Elantra N, should I decide to buy one.
@RDY4WAR
Do yourself a favor and stay clean away from Hyundai/KIA. unless you are keeping it for less than a couple of years and getting rid of it. There are other alternatives.What’s everyone’s opinion on the upper limit of Ca for LSPI prevention with small TGDI engines?
@RDY4WAR
@RDY4WAR
The issue with higher calcium oils that rely on additives to reduce LSPI is that they tend to perform a lot worse as the oil ages and the additives break down. A recent study by Lubrizol showed a tripling of LSPI frequency after aging an oil like this for only 6,000 km, and it would get worse than that on a longer OCI.It's the whole additive package that determines a good LSPI oil. One excellent way of determining that would be to select an oil based on it's specification meeting the engine builder. You're wanting to use that Elantra with Euro oil. Mobil 1 ESP Meets SP testing so that would mean it also passed SP's latest LSPI requirements. Just looking at the Calcium alone for LSPI is not the whole story.
I haven't seen that test but I've read about Magnesium decreasing fuel economy quite significantly. Yes, as oil ages things definitely can accelerate and deteriorate quickly. This whole LSPI testing is an ongoing test. SN+, SP, & future Standards will get better but keep in mind that Euro oils are formulated for long intervals so that should help w/oil aging. Did the Lubrizol show what standard of oil they tested?The issue with higher calcium oils that rely on additives to reduce LSPI is that they tend to perform a lot worse as the oil ages and the additives break down. A recent study by Lubrizol showed a tripling of LSPI frequency after aging an oil like this for only 6,000 km, and it would get worse than that on a longer OCI.
This oil may pass the LSPI tests for API SP and the MB standards, but it probably won't pass the LSPI test in the upcoming ILSAC GF-7 standard, which uses aged oil. An oil with less calcium would be a safer bet.
The study is SAE 2018-01-0934.I haven't seen that test but I've read about Magnesium decreasing fuel economy quite significantly. Yes, as oil ages things definitely can accelerate and deteriorate quickly. This whole LSPI testing is an ongoing test. SN+, SP, & future Standards will get better but keep in mind that Euro oils are formulated for long intervals so that should help w/oil aging. Did the Lubrizol show what standard of oil they tested?
The newer ACEA standards have just finally adopted the same LSPI test that has been used for API SP, but the new standards don't cover oils with HTHS >3.5. It might be a while before they update the standards for the thicker grades and add an aged-oil LSPI test.I've been reading up on Infineum website and two key ACEA standards are for sure targeting LSPI.
There are a couple of studies that have looked at oil viscosity vs LSPI, and there was little to no correlation.higher grade of oil & high octane fuel might help w/LSPI as well.
