Mobil 1 ESP 0w-30 VOA
NJ
This is recent per ROC (04/10/2025). It is not a counterfeit. The sample is from France. It looks very impressive. It appears this grade has not changed much at all since 2020, for some odd reason. I would have expected it to look like Mobil 1 ESP 5w30, which is also great despite the weak look add pack on paper. Some on the ROC are saying the new Mobil 1 ESP 5w30 is performing better than the oil FWIW. Not sure how they're determining that but it's been stated.
304 ppm of Born
77 ppm of Moly
Noack - 8.4% (excellent for a 0w30)
1,850 ppm of Ca
8 ppm mg
Here it is translated
TEST REPORT №1279/17 dated 10.04.2025
INFORMATION ABOUT THE SAMPLE PROVIDED BY THE CUSTOMER
Laboratory Number: 1279/1 dated 28.03.2025
Customer Sample Number: 7
Customer Name: LLC "Phoenix Lubricants"
Department: Tech Dept
Sample Date: 28.03.2025
Report Date: 10.04.2025
Oil Brand: Mobil 1 ESP 0W-30
Sample Location: Office, Plastic canister, volume 1L
Canister Code: G493212 dated 23/09/2024 027525
Sample Code: EMB76476A
Test Results
Parameter Name Unit Method Result
1. Wear Metals Indicators
Iron (Fe) | mg/kg | ASTM D 5185 | 3
Chromium (Cr) | mg/kg | ASTM D 5185 | 0
Lead (Pb) | mg/kg | ASTM D 5185 | 0
Copper (Cu) | mg/kg | ASTM D 5185 | 0
Tin (Sn) | mg/kg | ASTM D 5185 | 0
Aluminum (Al) | mg/kg | ASTM D 5185 | 1
Nickel (Ni) | mg/kg | ASTM D 5185 | 0
Titanium (Ti) | mg/kg | ASTM D 5185 | 0
Vanadium (V) | mg/kg | ASTM D 5185 | 0
Silver (Ag) | mg/kg | ASTM D 5185 | 0
2. Additive Elements
Boron (B) | mg/kg | ASTM D 5185 | 66
Magnesium (Mg) | mg/kg | ASTM D 5185 | 8
Calcium (Ca) | mg/kg | ASTM D 5185 | 1241
Barium (Ba) | mg/kg | ASTM D 5185 | 0
Phosphorus (P) | mg/kg | ASTM D 5185 | 809
Zinc (Zn) | mg/kg | ASTM D 5185 | 945
3. Contamination
Silicon (Si) | mg/kg | ASTM D 5185 | 2
Sodium (Na) | mg/kg | ASTM D 5185 | 0
Potassium (K) | mg/kg | ASTM D 5185 | 0
Lithium (Li) | mg/kg | ICP-OES Avio 200 | 0
Other Contaminants
Water Content | % | ASTM E 2412 | Absent
Fuel Content | Abs0.1 mm | ASTM E 2412 | 200.7
Glycol | Abs0.1 mm | ASTM E 2412 | Absent
Oxidation | Abs0.1 mm | ASTM E 2412 | 38.7
Nitration | Abs0.1 mm | ASTM E 2412 | 6.6
4. Physicochemical Properties of the Oil
Pour Point | °C | GOST 20287-23 (Method B) | Minus 56
Dynamic Viscosity (CCS) at -35°C | mPa·s | ASTM D 5293 | 5,858
NOACK Volatility | % | ASTM D 5800-21 (Method B) | 8.4
Kinematic Viscosity at 40°C | mm²/s | GOST 33-2016 | 64.56
Kinematic Viscosity at 100°C | mm²/s | GOST 33-2016 | 12.18
Viscosity Index | — | GOST 25371-2018 | 189
Acid Number | mg KOH/g | ASTM D 664 | 0.43
Base Number (BN) | mg KOH/g | ASTM D 2896-21 (Method B) | 8.43
Flash Point (Closed Cup) | °C | GOST 4333-2014 | 236
Sulfated Ash Content | % | GOST P 51947-2002 | 0.202
Mass Fraction of Sulfated Ash | % | GOST 12417-94 | 0.87
Test Results
3. Contamination
Other Contaminants
Something is off - boron is 304ppm and not 66ppm
Has not changed any? The more up to date VOA the better to spot any changes though.
Has not changed any? The more up to day VOA the better to spot any changes though.
Thanks, looks to be about the same. (y) We now have Noack too. 8.4%.
A colleague of mine performed a "teardown" on ESP 0w30. Shear stability, lubricity, and cleanliness are all outstanding. This should be everyone's goto universal oil. $28 5qt jug at Walmart is a bargain for what you are getting in this oil!
unlike us from europe ,we jave to pay 65euros for 5lt jug.and if its near you +10 euros for delivery cost.
