This thread taught me that I have not appreciated the rise in temps in bearings due to RPMs. I always thought the rise in oil temps was primarily due to combustion heat and oil interacting with the resultant "heat sink" in the chamber walls and pistons. I came to my old (incorrect) conclusion based upon how easy it is to turn a crankshaft by hand, surely the friction I felt couldn't create much heat....but that's only a few RPMs. Very different from a running engine.
Which brings me to an observation: My B48 engine runs at oh-so-low RPMs (it barely gets to 2000 RPM unless you encourage it to do so) for a 4 banger putting out over 300 HP and over 300 ft/lb of Torque. It's spec'd for 0w20. Therefore, as long as the RPMs are kept low, perhaps that 0w20 is sufficient for protection since the oil temps in the bearings stay relatively low. It's only those 4000+ RPM runs that really heat the oil.
I was already doing the reasonable thing by bumping up to 0w30, even if it was for the wrong reason! Now I know. Thanks for the education.
