Vibration between 60mph and 75mph
VA
I own a 2018 BMW M240i. I've been trying to find the sources of a vibration from what I think is coming from the left front tire/wheel. It's not the tire/wheel as the vibrations are there whether I have the summer tires/OEM alloys mounted or the winter tires/aftermarket alloys mounted. The vibes are there even after I had new front tires (Michelin PSS) mounted and road force balanced. I had my local indie shop (J &F Motors) check it. The owner Greg and his chief mechanic took it for a ride. They seem to think it's the driveshaft. BTW, the car has 44k miles on it. But, there's no vibration in the shifter (its a manual of course). There are no vibrations in the steering wheel when braking. Any ideas? Thanks!
Driveline vibrations are a weird thing in how they manifest and reverberate through the vehicle.
I believe most BMWs use giubos to connect the driveshaft to the transmission? That might be enough that it will isolate the vibrations from the shifter. I can say that I had a u joint cap in my pickup's rear driveshaft seize up a few years ago and cause a vibration. I could hear the terrible vibrations through the cabin and they were awful but couldn't feel anything through the shifter. And this has the driveshaft directly bolted to a yoke on the transfer case.
If the frequency is like 15-20 times a second (depending on tire circumference), it's rotational to the wheel/hub/rotor/cv ... etc. If it's really fast like 60times a second ... it's probably driveline related. The driveline spins significantly faster than the tires.
I've been fighting a driveline vibration issue in my Grand Marquis after swapping to 3.55 gears. I am running an unsupported config from ford - long steel driveshaft with 3.55 gears, ford never supported this for anything but 2.73 gears. The gearing I have now would have come from the factory with aluminium driveshaft / short tailshaft or the longer tailshaft / shorter steel driveshaft. If I am on the throttle or fully off the throttle between 65 and 75 I have no vibrations. But if I let up and there's a moment where there is no load on the driveshaft, it vibrates. The vibrations come from the front of the car, not underneath or from the rear.
Both the owner and the head tech said that the guibo and the center support bearing look fine. I think it's getting worse - across more car speeds.
I sent an email to the BMWCCA tech guru and after some back and forth he says it's the driveshaft. OUCH! I'll see if BMW NA can give some consideration considering that the car has just 44k miles on it.
Take it to a driveshaft shop and have them check it or fix it. I had my f350s carrier bearing, u-joints changed and balanced for a couple hundred bucks. Now, I did provide the u-joints as i was going to attempt to change them but the first cap was stuck, and to me it was better to have him do the work. I didn't have enough heat to get it out.
Thanks for idea, I'll look into it.
  • Like
Reactions: wlk
