Veggie Garden time
cptbarkey
$50 site donor 2024
texas
My wife has had a successful year transforming the front yard with flowers and a few trees. She has offered this year to grow vegetables, stuff we can pickle or can for fun. I thought about cedar pickets from Home Depot, but after pricing things out I decided free wood was more satisfying.
I've been running around a bit with the trailer the past month, last Saturday on a dead head return trip I picked up as many pallets as I could haul. Pallets turn out to be a great resource for garden boxes, as they already have wall boards, and plenty of 2x4s to brace everything.
During the week I broke them down, and de-nailed. I nearly filled a small parts container with nails. It took maybe a few hours of de-nailing with a framing hammer and nipper but spread over the week it wasnt bad.
Today was the perfect rainy and cold day to fire up the small diesel heater for the garage and get to work. Using the 2x4 as vertical supports, tacked the walls together with a brad nailer, drilled pilot holes, then finished with 2 inch deck screws. I played around with a planer but decided to skip it. It makes beautiful wood out of pallet wood, but what a mess.
Initially I thought working with disparate wood pieces would be challenging, but it was the opposite and kind of fun. If I couldn't span the full length, simply add more vertical 2x4 support braces and paste things together.
Ended up making two 6 x 3.5 foot boxes and that's enough for today.
I need to make probably 2-3 more boxes, lightly sand the outside to remove any splinters, then treat with linseed oil, then finally put into place and fill them up with dirt. The wife has ambitions of irrigating it all with pvc or vinyl tubing and emitters. fun.
Looks great for garden beds. I wouldn't want all that in my front yard (side or back would be better) but if it works for you and is kept up then so be it.
A bit of progress since. 4 boxes built, treated with linseed oil, put into place. 4 yards of rose mix and compost dumped in. The scope increased to the back fence line for more items.
Alot more progress since.
The Mellif tiller is a beast. My gas tiller will probably sit. It took about an hour to till the fenceline and two bars were left on 6ah batteries.
Supplemented half rose mix, half compost.
I cleared the back fence of weeds and little shrubs (no photos), then re-used landscape timber from previous garden boxes. I ended up having just enough.
Topped off the giant 40 ft box at lunchtime.
The wife is now free to plant in both areas. I ordered 120 feet of 3/4 pvc and various fittings. Next week trenching begins to make pvc irrigation. I already did a test dig with the tiller and I am confidant it will do the job.
Trenching has started for irrigation. Picked up some galvanized pipe to sleeve some of it so I can run over the lines at certain points with my 2k and 3k tractors without worry. I am only going down about 8 inches. The tiller is still holding up good and helping with the trenching. Maybe I should have planned irrigation first?
No going back on this scope creep train.
Undid the trenching. If I was outside the city limits I'd trench 5000 feet, but here apparently I'd have to pay jerk permitting process and nonsense. Instead will run semi-permanent garden hoses with strategic bumpers for walk areas. I did learn though the Mellif tiller will handle anything a mid level gasser would, so its a keeper.
Created 2 manifolds, routed 65 feet of PVC, and after testing, 1 garden bib services everything at full pressure, but wont really do more then that until pewtering out. Perfect.
The past few days, the wife wanted the U shape framed so she can hang frost cloth or bug protecting stuff. My truck was full of stuff I need to unload, and my trailer is also full of stuff I need to unload, so It turns out her van was perfect for hauling 30 2x4s.
She may also paint or hang lights or other fixtures. She is happy. I am happy, and I call it "Celebrating the Pallet Garden."
