Since I was replacing the fuel pump on the old Odyssey (teenagers DD) and decided might as well do a 2nd and final timing belt and water pump replacement (so I figured why not adjust the valves as well since it has been 110K since I last did them.).
What amazed me the intake plenum was coated in varnish and cylinders 4-5-6 where also had quite a bit of varnish. cylinders 1-2-3 were spotless like brand new. I would have suspected the rear cylinders (4-5-6) would gotten hotter (less air flow) hence would have formed more varnish.
I wish I took a picture of it. I was quite surprised how clean the rear bank was (like new) and yet the plenum and front bank was quite orange. This is the NON-VCM engine and only used synthetics since new either Mobil1 or Valvoline and most recently RGT, at 6-7K OCI. (approx 30 percent on OLM). PCV was not plugged and is maintained regularly.
What else would cause such a stark contrast in cleanliness?
