I hate to add another oil thread but Im not sure if Im understanding this right.
I came across a great deal at local discount auto parts. 31 bucks for 5 qts of oil (valvoline synpower 20w50) and a k&n oil filter for street glide.
My understanding was that any 20w50 type car oil would be good whether syn or dino. The only difference between the regular oil and cycle specific oil was if your using on a bike in which engine shares oil with wet clutch.
I found lots of posts supporting mobil 1 vtwin 20w50 and even valvoline vr1 racing 20w50 conventional or synthetic. But pretty much no posts for synpower. So now Im a bit nervous.
I contacted valvoline and they responded with the following:
"Valvoline Synpower 20W-50 will work fine in the motor, chain case, and transmission. The 4 Stroke Motorcycle Oil is good for Japanese bikes with a wet clutch that is lubed by engine oil. The Motorcycle oil will work fine in a Harley Davidson but the Synpower Full Synthetic will provide better engine protection and will run cooler."
and in comparing mobil 1 vtwin to synpower it seems synpower is a better oil on paper. Am I reading this correctly? Would like some feedback on this if this horse has not been beaten to death already. Thanks in advance.
Mobil 1 Motorcycle Oils V-Twin Valvoline Synpower
Engine/Application Type 4-Cycle CAR - LIGHT TRUCK
SAE Grade 20W-50 20w50
Service Classification API SJ,CF API SN/SM/CF
Density, 0.87 7.2
Flash Point, °C 214 230
Pour Point,°C -42 -33
Kinematic Viscosity@ 40°C 172.3 139
Kinematic Viscosity@ 100°C 20.8 19
Viscosity Index 142 155
Cold Cranking, cP 7,500 @ -15°C 4700 @-15
Pumping, cP 14,000 @ -20°C 10,100 @-20
Density, 0.87 7.2
