That was likely necessary (using the Star VII) in order to stay in grade due to the higher volume of VII polymer in the product.
The X4 is also slightly heavier out of the gate, albeit, not by a much. Again, both have to meet the stay in grade requirements for their approvals. For 229.5, that's 90 cycles in ASTM D7109, which is the same as for 229.51/52. If staying in grade in the KRL is important to you, then obviously the X4 is superior.
Yes, I think that's obvious based on the X3 -> X4 nomenclature change.
They both carry A40.
The X4 has: C40, 511 00, MB 229.51/229.52
The FS has MB 229.5/229.3, VW 502 00/505 00, BMW LL-01
Some of these prioritize different things. 229.51/229.52 caps TBN at 6 for example, but has more stringent oxidation resistance parameters. 229.5 has a higher load carrying capacity limit, and the only one with a limit using aged oil. 229.51/52 is tested in the OM651 and 642 but not the M272. 229.5 is tested in M271 and M272 but not OM651/642. 229.51/52 has higher piston cleanliness requirements on the OM 646 diesel engine (16 merits vs 14 for 229.5).
Would be helpful to have the current details on the LL-01 test procedures, as that of course adds another dimension, as well as VW 511 00.
For Mercedes, the 229.51/52 approvals prioritize diesel performance, while 229.5 prioritizes gas.
I think you mean 502 00/505 00? FS doesn't carry 504. I'm not sure how you are concluding the additive package is "more higher end" unless you have access to data we don't (the latest copy of the Afton handbook I have is 2019, so it doesn't have 511 00 in it). Also, the FS additive package isn't all that old, because it was recently updated to carry LL-01 again.
This is based on what, the higher cost of the Star VII? It can't be the PAO. Assuming this is an Infineum additive package, I'm genuinely curious as to what this is based on.
Nobody is claiming the SDS is a recipe. They do however show that both oils are based very similarly, both using GTL as the primary base, while the FS appears to lean a bit harder on PAO (and less VII), while the X4 likely leans a bit harder on a thinner GTL base and more VII (albeit, Star VII).
And that's fine, if it's just your opinion, that's why I asked.
And that's why I'm running the HPL Super Car (which is formulated using the A40/LL-01/229.5 full-SAPS additive package, the horror!
