- Joined
- Dec 20, 2024
- Messages
- 1,721
My Royal Purple was neither better nor cheaper. Eight years worth, about 2.5 changes/year.... "better, cheaper synthetics that meet the specifications" and had issues.
Yep. Another case in point.My Royal Purple was neither better nor cheaper. Eight years worth, about 2.5 changes/year.
I didn't know many new cars were GM. If its not then this Dexos voodoo is irrelevant and maybe more so since they decided 0w40 was a fix to their disaster of a car company. I think you can get a really good product to the customer from many non dexos lubricants.One piece of evidence is that it lacks the Dexos seal, which many new cars require.
Rightfully so too. The minority is ruining it for the masses. What makes Dexos better than VW or Toyota specifications? Im impressed only with the Valvoline Restore and Protect 5w30 & Valvoline Extended Protection High Mileage 5w30 and I see no dexos stamp of extortion on either. Pennzoil Ultra Platinum has too much going for it to be Dexos and in theory, they should crank up the hths and turn it in a poor mans Redline Oil.Many top offerings don’t get Dexos. PUP for example. Cost and relieving recipe is a turn off for them.
So, your heart was in the right placeI’ve maintained this vehicle since new with Quaker State Full Synthetic for a friend. Varnish visibly started around 45k at 150k now.
I started doing oil changes on a 2017 Kia Sorento 3.3L DI NA engine that got oil changed at the dealer most of its life . After the1st OCI of Mobil 1 ESP 0w30 that I did I found carbon chunks (like you show) and varnish on the dip stick started to improve . Now half way through an OCI of Mobil 1 ESP 5w30 plus I added a bottle of Rislone engine treatment I had on hand and the cleaning has continued . I’ll trust a 30 weight oil is still OK for the Kia 3.3L DI engine but next OCI will be Valvoline Restore and Protect 5W30 as besides its cleaning abilities it runs very smooth and quiet in other Hyundai / Kia engines I have (2.4L DI Theta II , 2.0L MPI Nu) . If I left Valvoline Restore and Protect for another oil (after Valvoline Restore and Protect ran for 5 OCI’s) - it would only be to go back and use Mobil 1 ESP 0w30 or possibly try Pennzoil Ultra Platium 5w30 after Valvoline Restore and Protect finished cleaning.You don't have any that require cleaning that you know of.
Not Valvoline Restore and Protect at that time. My sons high mileage Forte, didn't burn any oil, I've cut every filter for last 6 years and 50K+, always clean pleats and can. It used to have a decently loud piston slap type sound when cold (worse in winter). I did BG EPR flush, didn't change anything that I could tell, no junk in filter all the times running Mobil 1 Advanced Fuel Economy and PP. I decided to run some HPL Engine Cleaner 30, about 1/2 way through the OCI it was noticeably quieter at start up to the point my wife asked what I had done. All I can guess is that rings got freed up some allowing proper movement/centering in cylinder. At the end of that OCI this was in the filter with a lot of little carbon specks in pleats. It had a leaking VCG for awhile and when I tackled that right about same time as EC30, the top end looked like this with about 185k. It always looked clean through fill port prior. It's currently running Valvoline Restore and Protect 5w-30, I'll see it at Thanksgiving for it's first oil change from that. We'll see how filter looks.
Dexos is not the highest standard, but reflects a good all round series of oil performance tests. GM is the fourth largest automaker, so does produce a good number of new vehicles. The oil change you are talking about concerned one engine, I believe. Respect for the high mileage achieved on your modified Honda.I didn't know many new cars were GM. If its not then this Dexos voodoo is irrelevant and maybe more so since they decided 0w40 was a fix to their disaster of a car company. I think you can get a really good product to the customer from many non dexos lubricants.
DEXOS is a joke i.e. “pay to play” license. I wouldn’t go out of my way to buy a DEXOS certified oil. I’d use Mobil 1 0w/5w-30 oilDexos is not the highest standard, but reflects a good all round series of oil performance tests. GM is the fourth largest automaker, so does produce a good number of new vehicles. The oil change you are talking about concerned one engine, I believe. Respect for the high mileage achieved on your modified Honda.
Mobil 1 0w/5w-30 oil is DEXOS unless you are talking about ESP line and I think you are.DEXOS is a joke I e “pay to play” license. I wouldn’t go out of my way to buy a DEXOS certified oil. I’d use Mobil 1 0w/5w-30 oil
C)Ignoring ideal driving conditions, OCI and oil selection. Which of the following is a more reasonable perspective?
c) Some new engines have ring issues.
D) That oil choice can remedy.
GM produces a good number of vehicles. Ok, I agree.Dexos is not the highest standard, but reflects a good all round series of oil performance tests. GM is the fourth largest automaker, so does produce a good number of new vehicles. The oil change you are talking about concerned one engine, I believe. Respect for the high mileage achieved on your modified Honda.
My Corvette has a 6.2L engine and it’s working just fine with 118,000 km on it.GM produces a good number of vehicles. Ok, I agree.
GM does not produce good vehicles. Just a number of vehicles with defective engines. 6.2 V8.
An LS3 or similar? Not an engine with defects. The 6.2L GM engines with issues were truck engines (L82).My Corvette has a 6.2L engine and it’s working just fine with 118,000 km on it.
It’s the LT1 and I know it’s not the same as the ones with defects. But it’s still a good example of GM getting things right. They’ve produced more reliable engines in their history than unreliable ones, by a long shotAn LS3 or similar? Not an engine with defects. The 6.2L GM engines with issues were truck engines (L82).
https://www.caranddriver.com/news/a...-tahoe-cadillac-escalade-defective-v8-recall/
What percentage of the 113 million SB V8’s is that ?GM produces a good number of vehicles. Ok, I agree.
