Valvoline Restore and Protect cleans rings and other areas of the engine without engine disassembly.![]()
Sure worked for me, no other top shelf or bouquet oil cracked the carbon jammed rings seal on my rings, with years of multi use. The first 1,500 miles of use, then no fuel dilution. It may not of clean them fully like Valvoline Restore and Protect, but it sure cracked the seal wide open on my problem.Dave G. from Redline told me a few times that the esters used in Red Line ran clean but wouldn't clean. I thought that was interesting. With so many esters though it makes sense. But initially I was surprised by that.
...Dunno. My personal opinion is many people are seeing what they WANT to see...
So, tell us what YOU see here?
I see excellent marketing
The better mousetrap was never the best seller....it was the best MARKETED mousetrap that brought the gold.
Like I said...detergents are known to clean engines. If it has more detergents in it....good.
Do you know what "YMMV" means ? Did you see that in the post?
Yeah, that's Premium Blue Restore, which has a huge dose of ester:did not see where it notes any name, Patent No .: US 11,078,436 B2
at least shows where there head is at?
US Patent 11,078,436 gives a good idea of what Valvoline Restore and Protect is about. Specific base oils from Groups III, IV and V blended to a specific aniline point provides the solubility needed to remove deposits. A patent doesn't provide specific commercial formulas but it will give an idea of the technology behind the invention. Valvoline Restore and Protect is not a solvent but it has relatively high solvency characteristics. It certainly isn't micro-abrasives which is counter to lubrication principles and best practices.
However, greases with abrasives have been used in...
No, detergents don't clean engines. They are designed to prevent deposits. The detergent and dispersant package is designed to provide two functions:I see excellent marketing
With the healthy amount of Moly and Boron on top of the cleaning power at a very reasonable price point I’ll support that strategy.Valvoline's videos indicate that they deliberately selected a low concentration of the magic additive in Valvoline Restore and Protect - it's not a lack of capability, it was a deliberate decision to reduce the cleaning effect.
They claim it was to prevent accidental filter overloads, but there's probably also a strong component of product planning strategy in there too. If you can make the customer buy a minimum of 4 oil changes worth of your oil instead of, say, 2 (assuming they increased the additive concentration and therefore the cleaning action), seems like free money to me.
