I can't recall. Did you notice the noise around the same timeframe? 3000-3500 miles?Exactly the same thing. Good to know I’m not the only one!
Right around 3k if I remember correctly.I can't recall. Did you notice the noise around the same timeframe? 3000-3500 miles?
There's a thicker grade for my purposes. My neighbors 03 Honda CR-V has been having Maxlife Blend 5w20 go through it likethrough a goose. I suspect it's burning oil, but I still haven't conclusively diagnosed it. I'm going to put Valvoline Restore and Protect 5w30 in it. For her CR-V 5w30 is a higher grade.
However, I understand what you mean. There's no Valvoline Restore and Protect grade higher than 5w30 in USA.
I don't know what brand/version of 5w20 oil what used in the 03 CR-V in the past. It would have been whatever a local quick lube place put in. My cousin recently put Valvoline MaxLife Synthetic Blend 5w20 in it. I wish I'd have had him put in Valvoline MaxLife 5w30, or ideally 5w30 Valvoline Restore and Protect, but hindsight is 20/20.That will be interesting. Keep us posted, please.
Don't tell me they were running Maxlife synthetic blend at 5K miles OCI.
I was running my '98 Civic on Maxlife 5w30 for about 10 years and there was a lot of varnish on the valve train when were replacing the timing belt. However, I think it was a good oil for that time and for my needs. I was dumping it every 3-4K miles OCI. I regret that I wasn't running the Civic on Full Synthetic from the very beginning as the guy I sold it to.
Goodness and here I thought hindsight was 0w20.I don't know what brand/version of 5w20 oil what used in the 03 CR-V in the past. It would have been whatever a local quick lube place put in. My cousin recently put Valvoline MaxLife Synthetic Blend 5w20 in it. I wish I'd have had him put in Valvoline MaxLife 5w30, or ideally 5w30 Valvoline Restore and Protect, but hindsight is 20/20.
Does that really matter? Maybe if you drive a GM vehcile.Main con is the lack of Dexos 1 approval.
I believe GM Dexos 1 Gen 3 approval has tighter standards for sludge, volatility and LSPI than GF-7. So, lack of approval for this standard, or even a claim to meet it, means the oil could potentially perform worse in those categories.Does that really matter? Maybe if you drive a GM vehcile.
I guess application plays a roll also. Not everyone is driving around DI engines.I believe GM Dexos 1 Gen 3 approval has tighter standards for sludge, volatility and LSPI than GF-7. So, lack of approval for this standard, or even a claim to meet it, means the oil could potentially perform worse in those categories.
I don't either, though I must admit, Valvoline Restore and Protect seems to do it cheaper. But as I stated before, I like to stay around 3.5 cP HTHS viscosity so 5w30 in it's current form is only 90% there.No gummy or sticky rings in 25 years
Let me see. Nope don’t need Valvoline Restore and Protect.
After Valvoline create the market, others will want a share.On a more serious note. Why would anyone wanting to clean their engine buy an unproven product when Valvoline Restore and Protect is already proven?
According to Valvoline, Restore and Protect is approved and licensed, protecting GDI engines from LSPI. As for sludge, I don't think that would be a problem since the oil is able to clean. Lastly, Noack is under 15%, which can be anything lower than 15%.I believe GM Dexos 1 Gen 3 approval has tighter standards for sludge, volatility and LSPI than GF-7. So, lack of approval for this standard, or even a claim to meet it, means the oil could potentially perform worse in those categories.
Yeah if it had a high hths like 3.3+
https://www.amsoil.com/p/amsoil-extended-life-5w-30-100-synthetic-motor-oil-xlf/?zo=515729Is there 5w30 resource conserving oil that has HTHS higher than 3.3 cP?
The Valvoline Restore and Protect has 3.24 cP per Valvoline (page 1 of this thread).
Valvoline Restore and Protect is the highest performing oil in their line. They told me it would absolutely meet/exceed dexos. It's not a performance issue but licensing.According to Valvoline, Restore and Protect is approved and licensed, protecting GDI engines from LSPI. As for sludge, I don't think that would be a problem since the oil is able to clean. Lastly, Noack is under 15%, which can be anything lower than 15%.
https://engineoil.api.org/Directory...csResults?accountId=-1&companyName=AmsoilThanks.
Are all these 5w30 resource conserving oils like the Valvoline Restore and Protect?
