Buy the next higher grade.No but it doesn't seem very shear stable, and combined with fuel dilution I see it dropping well below 3.0 in use. If it was shear stable I would be content with 3.2 cP
Unless you live in Australia, there is no higher grade.Buy the next higher grade.
There's a thicker grade for my purposes. My neighbors 03 Honda CR-V has been having Maxlife Blend 5w20 go through it likeUnless you live in Australia, there is no higher grade.
Grades lower than SAE 30 don't exist to meThere's a thicker grade for my purposes. My neighbors 03 Honda CR-V has been having Maxlife Blend 5w20 go through it likethrough a goose. I suspect it's burning oil, but I still haven't conclusively diagnosed it. I'm going to put Valvoline Restore and Protect 5w30 in it. For her CR-V 5w30 is a higher grade.
However, I understand what you mean. There's no Valvoline Restore and Protect grade higher than 5w30 in USA.
What is an eye opener here is that you can have a pristine engine inside - but if you have piston / piston ring deposits (as this K24 engine has) your engine from this carbon deposit situation alone could fail . It’s nice that Valvoline Restore and Protect can remove sludge and varnish but Valvoline Restore and Protect’s ability to clean piston and oil ring carbon deposits is really , really key .Indeed, the the "I do cars" teardown of a pristine Honda K20c4 caught my attention because the engine was immaculate all the way through the teardown-- until he actually got the pistons out and found the stuck oil rings-in less than 100k miles. Seriously, it took physically removing the pistons to identify any potential reason the engine was removed from service. The rest of the engine was utterly immaculate with zero deposit residue anywhere.
The evidence is strongly suggesting to me that cleanliness of the ring pack is perhaps the single most important property of an oil in terms of how it affects the engine's life. Because if you Pareto out the reason why engines leave service, the first and largest factor BY FAR is "oil consumption". And what's the largest cause of oil consumption? Piston/ring deposits.
Valvoline Restore and Protect is the right product at the right time, notwithstanding the naysayers.
I don't think other manufacturers will do it. By the time they could get around to it, it'll be too late because all Americans who care will already have clean engines.Good point!
As we BITOGers sit with popcorn in hand waiting for the other motor oil manufacturers to offer a similarly performing product.
I believe it’s simply a matter of time.
I think a lot of consumers who would change their oil don’t understand the importance of what may be going on with the oil rings and carbon build up . They think about as far as sludge prevention or sludge clean up and believe they are doing good with other WM available synthetic oils that meet SP / Dexos.I don't think other manufacturers will do it. By the time they could get around to it, it'll be too late because all Americans who care will already have clean engines.
On a more serious note. Why would anyone wanting to clean their engine buy an unproven product when Valvoline Restore and Protect is already proven? Valvoline could drop the price of Valvoline Restore and Protect to make any new competitors regret their investment.
No risk. It’s an outdated concern that didn’t materialize. I would run Valvoline Restore and Protect without hesitation. I’m running it a 20 year old truck that has only seen conventional oil ever. No new leaks. I have a valve cover gasket leak (had it when I bought it), but it didn’t get worse. Got a good amount of crud out of the engine on my first interval with it on just 2000 miles or so. I may run it forever. Glad to hear your positive report with Valvoline Restore and Protect in your truck.Third owner on my truck and had the Coyote typewriter/ticking noise. I bought the Valvoline Restore and Protect claims and because I didn’t know the history of the first 60k miles for oci, decided to run it for 3 changes. On my second interval with Valvoline Restore and Protect 5w20 and the ticking is gone. Notice that my last two trips to the lake, my MPG is 1.4 better than before. Same fuel. Same driving style.
I picked up a ford 4.0 v6 Explorer for my son with 206k on the clock last year. Religious OCIs from prior owner. Still burns a little oil. 5w30 semisynthetic is what’s it’s always gotten. Would there be any cons to running one or two oci with the Valvoline Restore and Protect? I have been using the Red MaxLife jug in it, but always heard of moving up to Full Synthetic being a risk on seals and what not for older engines. No leaks, and I don’t want to toss in a new product and create a problem for myself.
I called Valvoline, as far as Valvoline is concerned, a USA Euro Restore and Protect oil is not in the cards I was told. ( I asked in a 0W/5W-40) ................3 different customer service/techline operators in a 2 day span. " we are getting calls on that, but """we were told Valvoline is not interested in offering it into the USA market any time soon.""""If Valvoline could offer a Euro version of Valvoline Restore and Protect it would be great. Or even just plain API but in off their weights like 5w-40, 0w-40 or even 0w-30.
Good point, and I'm considering that. But also I think the carbon build up is all from 225k of conventional oil on annual changes. I think a quality synthetic like Kirkland changed twice a year or every 5k could keep it clean, but I'm still not sure.If it’s running better after a few changes of Valvoline Restore and Protect why would you switch to anything else?![]()
I think that @Glenda W. also noticed increased noise on her Valvoline Restore and Protect changes IIRC (not right away, but like yours, part way into the OCI).Used the Valvoline Restore and Protect 5w30 in 2AZ-FE powered 2008 Scion xB.
- It did clean the rings and eliminated the oil consumption completely. That's a PRO, as I didn't even have to do a piston soak.
- Here is the CON: after more than 3000-3500 miles on the oil the engine gets noticeably louder. Not sure if that's valvetrain or timing chain related, but it's very noticeable and I now use that rattling sound as an indicator for the oil change. A colleague noticed the same in his 1NZ-FE powered Toyota Yaris.
Exactly the same thing. Good to know I’m not the only one!I think that @Glenda W. also noticed increased noise on her Valvoline Restore and Protect changes IIRC (not right away, but like yours, part way into the OCI).
Oil can pass all of the dexos 1 tests, but you cannot say it on the label until you sign a very expensive contract, a separate one for every grade (viscosity) of oil you sell. So, do with that information what you will.Main con is the lack of Dexos 1 approval.
Yeah if it had a high hths like 3.3+0w30 would be a great.
