Valvoline Restore and Protect drawbacks?
Look in your owners manual and see what it says for oil choices and for severe service schedule. The 2 Hyundai's I currently service '21 Tucson 2.0 and '21 Sonata 2.5 both have the MM but you decide the interval. The Tucson was very short trips, fuel dilution that oil level on dipstick would rise. 5W-20 was recommended, 5W-30 optional. I bumped up a grade to 5W-30 using Valvoline Restore and Protect, changed interval to 3k/6 months. My son just changed the MM to 4k/6 months as drives are now about 20 minutes each way.
The Sonata didn't have the MM activated and records were "not so good" of last change. That now has 5k/6 months enabled but sees at least 30 minute drives most of the time. When it first came to me it was almost 2qts low, needed a top off a bit later. Currently on 0W-20 Valvoline Restore and Protect and at 2100 miles in hasn't used any oil.
The severe service schedule according to Hyundai is what I consider normal. Up hills, down hills, dusty, extensive stop/go, salt and probably 10 others like sunny, windy, rainy, cloudy or any day that ends in Y.
Mine is 0w20 only, all weather conditions. No other viscosities are mentioned, maybe 5w20 with the admonition to get it swapped out no later than severe service mileage. It doesn’t elaborate on likely OCI miles, unless I missed it, but severe is 5K miles (I think). Probably worth mentioning, mine will be doing a lot of electric only miles within that 33 mile range. I’ve only put gas in it once since bringing it home from Yuma toward the end of September.
I tend to take the manufacturers word and therefore I consider Valvoline Restore and Protect to be their highest performing product. It could be marketing and I see his point. I have no reason not to believe them though. Everything they've said about Valvoline Restore and Protect was true. Valvoline also can run every engine test internally so they would know what product of theirs is the best.
I agree in this instance that Valvoline Restore and Protect is their highest performing product, and that it excels in cleaning and keeping an engine clean. IMO as far as oils that clean, I trust their claims more than any of the others making engine cleaning claims at the moment. Having said that things can change, my bet is their competition is noticing this product gaining traction, and they're looking to address it. This is how products evolve and improve.
Valvoline claims it can be used lifetime from new. Personally I wouldn’t go over 5k oci’s.
My understanding was it would go whatever the maintenance minder was calibrated for on your vehicle. Im sure in a car with under 20k miles you wouldn't have much to clean up. I go 5-7k on it, siphon out through dipstick, then run it again, and then do the same thing.. Again. After about 20k, I have dealer drain and I use another fram ultra or purolator boss.
Im liking it not having a Dexos label on the Valvoline Restore and Protect! Starting to think 🤔 they can kinda push the limits and bring a better OTC oil to the shelves kinda like Pennzoil Ultra Platinun and a few others.
Back to the OP question. The only drawback is it's just an API SQ/GF-7 oil, if you consider that a drawback.
Yes. I should do that. I can tell you, so far, 3k miles in, the 4Runner's 1GR-FE engine seems to like Valvoline Restore and Protect 5W-30. It feels smooth and torquey.
Here's an update: 6k miles in, wife reports, "So far, according to the MPG computer, the 4Runner has seen an MPG increase since the oil change".
Question: Valvoline says 4 oil changes for cleaning, but what about in a low mileage (presumably pretty clean) engine? My ‘24 Tucson plug-in has just over 10K miles on it, and according to CarFax has had 2 oil changes. I’ve had it about a month and a half and have only used 1/8 of a tank since getting it home from Yuma, so mostly plugged in EV driving. I have no idea how it was driven before I got it (obviously ;^), but how dirty could it be? Would one cycle of R&P likely clean up whatever may be in there now? I’m thinking long term I want to run Mobil 1 ESP X2 0w20, but maybe clean things up first?
I think either oil would be fine.
With that use, I sure would use 91 octane non-ethanol with a splash of Sta-Bil.
I'll agree a Euro flavor would be good, but both for older and new engines so the zinc fans can get theirs and one so rest of us can use an LL-04, MB229.5x, C3 option.
I have both, but have no problem using the LL-04 in our BMWs because BMW backed spec'd to LL-04 fromLL-01 in the N52. They're easy on oil.
Lakespeed has a video about how choice of gas brand affects piston rings and cylinder wear. His tests showed that choice of gas brand does affect wear.
I wonder if, or how, choice of fuel also affects cleanliness of rings.
I personally only use Shell premium in both vehicles as they require use of premium. I believe the add packs that the majors use, changes the burn characteristics of the fuel vs generic and no fuel additives
Or 0W-40. Need a Euro spec flavor with higher viscosity and much higher ZDDP content, at least 1,000 PPM. The current RP offerings are weak sauce, unsuitable for my cars.
If it has higher ZDDP it won't be API SQ and ILSAC GF-7. Then people will say they won't buy it because it doesn't cover those specs. As people say now that is a drawback that is not Dexos1Gen3 approved.
If it come up as 5W-40 or 0W-40, but is not API SQ and ILSAC GF-7 - are you gonna buy it?
A lot of great explanations and discussions here. I'm going to throw one more con into the mix.
If you follow rebates and promotions (like I do), you may likely get a far better bang for your buck by simply the best motor oils for less money.
This is of course assuming that you don't have problems with your piston rings or other major contamination issues. If you already have those issues than R&P is obviously a top choice so long as it isn't fuel contamination.
Most folks here don't have these issues, and their money will go further by shopping for great oils that have a big rebate.
Earlier this year I was able to get 10 quarts of Pennzoil Ultra Platinum Full Synthetic for just $2.08 per quart. Valvoline Restore and Protect costs three times as much at Walmart.
$40 of savings every year times 10 years at a 10% interest rate... comes to $634.95. That's a healthy savings.
There are plenty of other motor oils that will likely improve longevity and cost less than R&P. So unless your engine isn't operating as it should, a high quality oil with a solid rebate will be a better choice.
The only "drawback" I see is that you are limited, per Valvoline, to the car manufacturer's recommended OCI. Is it THE BEST? Is it the cheapest? Will it guarantee a million plus miles on your engine? Would something else do a better job in your car? I guess all of that is debateable, but it seems to me that Valvoline Restore and Protect is a great oil for most people.
The chances are there is pretty much nothing to clean. A single oil oil change should do the trick
