Originally Posted by Impatient
I read through your bench tests, but do you have any report on the usage in the Ranger yet?
I didn't get a used oil analysis on it, which would have been interesting. I got it partly out of fascination with it as well as the fact that the AMSOIL Signature Series that I used previously got dark at low mileage, so I thought there may have been some deposits to clean up. The two prior oil change intervals were with Mobil 1 Extended Performance 0w20, which made the engine quite noisy and the oil did not darken much. With the Valvoline, the engine was much more quiet and it ran a bit smoother. It did not darken much until around 4K miles and I changed it at 5k miles. I recently learned that other people also noted that AMSOIL Signature Series turned quite dark for them too, so I suspect that mine did not turn dark due to deposits and that I had little need of using Valvoline Restore. That's ok since I'd rather that be the case anyhow.
