What is the typical oil change interval for a Cummins ISX15 Engine?
I am currently running Valvoline Premium Blue Restore 10W-30 which is an oil designed to clean piston rings on ISX15 engines. The instructions state to run the special oil for an entire oil change interval, so I assume that I will need to run my oil for a similar distance in order to achieve the desired results.
