Cummins ISX15 OCI
CA
What is the typical oil change interval for a Cummins ISX15 Engine?
I am currently running Valvoline Premium Blue Restore 10w30 which is an oil designed to clean piston rings on ISX15 engines. The instructions state to run the special oil for an entire oil change interval, so I assume that I will need to run my oil for a similar distance in order to achieve the desired results.
The Critic, There is no comparison between what an ISX15 experiences and what a 2007 Honda sees. Sump size, diesel vs. gasoline, soot loading, filtration, highway vs. city driving, engine design, you name it, and its different.
That said, your Restore has extremely tough base stocks & additives, so you can go 10,000 miles or 1 year in my estimation, easily.
Probably want to change the oil filter every 3,000 miles to make sure all the stuff coming off the pistons & elsewhere doesn't get too clumpy in the filter.
Use a Fram Ultra for best capacity.
