Originally Posted by tiger862
Originally Posted by PimTac
There is no such thing as 0 weight oil as far as motor oil is concerned nor is there a 0 grade.
Here we go again.
A single-grade engine oil, as defined by SAE J300, cannot use a polymeric viscosity index improver (VII, also viscosity modifier, VM) additive. SAE J300 has established eleven viscosity grades, of which six are considered Winter-grades and given a W designation. The 11 viscosity grades are 0W, 5W, 10W, 15W, 20W, 25W, 20, 30, 40, 50, and 60. These numbers are often referred to as the "weight" of a motor oil, and single-grade motor oils are often called "straight-weight" oils.
https://en.m.wikipedia.org/wiki/Motor_oil#Single-grade
You have to remember that these grades are just a classification of the range of the viscosity, so they are not units of measurement. They classify the viscosity (which is the unit of measurement in cSt ) @40°C and @100°C.
A 20W rating will be around 150cSt while a 20 weight will be around 8 cSt.
Here we go again.
