So, except for having to get under a car, what is the advantage to pumping used oil vs draining it? And, how do you know you have pumped out all the old oil? Are oil stick tubes always in the lowest point of the oil pan? Just asking. This is a new concept to me. I find it curious that those of you who do it seem quite converted to the concept.
I have installed a Fumoto drain valve on my Outback. the valve accepts a hose barb, that has a 3/8" hose attached. With this I drain the motor oil right into the empty jug, for return to the auto parts store for recycle.
Even if I weren't using the Fumoto valve, it seems the number of steps are the same. Drain oil into a drain pan. Pour from drain pan to empty jug, to take to auto store. Or, pump oil into pump. Transfer oil from pump to empty jug, to take to auto store. Unless you take your pump directly to the auto store, and directly pour it into the recycle tank. Which, I would rather not do. Most of the recycle tanks I have seen are nasty dirty. I'd rather not be anywhere near them, unless I were in work clothes, which I typically am not, when I go to the store.
Am I missing something? Please share what is attractive about the pump method.
