It has been sitting there for 4-5 years.I’m actually not concerned with mixing. I’ve done it and will again.
The pin hole comes with intrusion is my fear
$10 -$20 or less in oilIt has been sitting there for 4-5 years.
NEVER do this as the can just rips.Take a long, thin chisel or screwdriver and pierce the filter until it come out the other side. Righty tighty, lefty loosey
I have one like that . I hate the downward facing drain spout .Details are the story here.
How well are you equipped?
Got ramps? Considering doing something dangerous with whatever jack you have?
IF you need to buy a catch pan, get an "open style", like this.
https://www.amazon.com/WirthCo-32953-Motorcycle-Prevents-Leak-Proof/dp/B009KVSYOE?crid=1I26HIZRRN3RB&dib=eyJ2IjoiMSJ9.4ob5fVZlv8efhktluNAdW4P72yszOZz5COjMLfW8Oeqw3ali3-0MXvpBhgUvQrhr8aJGcHim1ao70abLymM1FWqDxlLFC7nDNqY6EJ8KF8TZqmlFGbXZ4j0hQzoFVQIpT3tpK7DZk_BOmVg0OONSeOFjaNA1IEsOWtDmVwVNyMJmX780HD2hByKHDzTslP4eK57gRH3KW8iT9SFsxDs-pE7__xf5xIW_l8QmmgFuu5WszOS7g7GlKH0UFM9xPBLi1r8zqVLZ4zHrd4_2fA5YxAvgc5aL-IEI6zJDiYDRjqE.SHbkPRGniAcU4ZfdZXAPVZolg-M1dFsaF6vcTlyxwMQ&dib_tag=se&keywords=oil+drain+pan&qid=1752862523&s=automotive&sprefix=oil+drain+pan,automotive,115&sr=1-19&th=1
Other styles splash a lot.
I was fortunate that the plug is on the back so I could use my rampsI have one like that . I hate the downward facing drain spout .
99% sure you're two qts low. The interweb says 7 qts for the 5.4 in a '14 Navigator. This has been my experience with pretty much all full-size truck 5.4 3Vs. I think you get the 4V? but it appears crankcase capacity did not change.I did it today. Couple of observations…
1. The quick change place really tightened down everything. I had to get a long wrench and a hammer to budge the drain plug.
2. The 5 quart container* seemed to fill it. I’ll check it in a day or two after a little running. **
* found an intact container of Pennzoil platinum 0w20 that I used.
** roofers showed up a day early and were rushing me
Finally got out to be able to check today. You are (were) right. It was just over two quarts in fact. When I pulled the dipstick today it didn’t even really register. Was so rushed and had no light to really see the dipstick as I was finishing, it may well have been the same and I saw it wrong. It’s filled correctly now and looks line I got everything in place correctly (ie no leaks).99% sure you're two qts low. The interweb says 7 qts for the 5.4 in a '14 Navigator. This has been my experience with pretty much all full-size truck 5.4 3Vs. I think you get the 4V? but it appears crankcase capacity did not change.
