V-Tail Bonanza's ??
Some of my earliest memories as a child are of whacking my head on a Bonanza wing. My late father ( a dentist ) had several V Tails - the last I recall being an S Model sometime in the mid to late 60's. He had numerous airframes over the course of his life, up to and including a Citation, but I believe the V Tails were always his favorite, so much so I had that one engraved on the back of his tombstone.
Other than color schemes, I don't recall much about them because of my age at the time. I did get to fly in them a lot and seem to recall all of them having a bit of a side to side sashay, even though the S model had a yaw damper (IIRC).
Later when I was out of school and had my ticket and some time, I recall talking with him about the tail controversy and he seemed to be on the pilot error side of things. He said they were a clean airplane and could get away from you very fast if you got the nose down with power on.
edit: I would also add that they were a roomy airplane, that was fast for its size - not like a Mooney where you feel like sardines stuck in a can.
Hang out in aviation long enough and you'll learn that any somewhat affordable airplane out there has a "doctor killer" added to it. The Bonanza was the "V-tailed doctor killer".... the Tomahawk was the "T-Tailed doctor killer".... The Ercoupe, the "No Rudder Doctor Killer"..... The "Cessna 17-2 Doctor Killer, 17 hours a year, 2 people dead"... etc etc.
The planes werent killing the doctors, the doctors were killing the planes. Wealthy enough to afford the plane, but dont fly often enough to be proficient.
I never heard of the Tomahawk as a Doctor killer...I thought it was a much more indiscriminate killer, spinning you in regardless of degrees or professional certifications. Also, if all a Dr. could afford was a Pa38, not sure I'd use them :D In all seriousness, I had a Tomahawk for 5+ years and I absolutely loved my little T-tailed devil.
All basic, common GA airplanes fly the same and they also all fly different.....that said, the only noticeable handling trait I noticed in the V tail is the slight 'wagging' as others note.
I will say though, the V tails do have one distinguishing trait; absolute beauty.
How did I miss this thread? I love the Bonanzas....someday!
My uncle had a Navion with tip tanks. Had it for years. Sold it a couple decades ago. My father was a part owner of a Cessna 150. He piled it up in 1976 on a gravel runway in Manton, Ca. More than 100 degrees out with a creek and power lines on one end. Underpowered plane, inexperienced pilot. He walked away, neraly tore his nose off and broke a bunch of ribs. Plane burned into molten aluminum mostly. Last time he ever piloted a plane. He's still kicking, barely, at 91 years old.
I got my private in a Tomahawk. It's a fun airplane to fly and pretty darn easy to land. I soloed it at 5.6 hours total time, which now scares the heck out of me. My private training was done at ALO (Waterloo, IA) which has a tower and three huge runways. You could take off, land, come to a full stop, and take off again on any runway there. The first time I saw a narrow short grass strip, I thought it was a joke that we could actually land there.
I absolutely love the Beech Bonanzas. My favorite model Bonanza is the S35. Came out in 1965 or 66. It is the lightest V tail with the Continental IO-520 engine. Basically, the first year of what I call the big block engine.
I used to teach in the Bonanzas and considered it the best sorted single engine airplane available. I like them better than the Cirrus.
If I ever can afford it, I would like to have a Bonanza, especially from about 1966 on..
How did the Aircoupe (sp), fly without a rudder?
I’ve flown several Ercoupes. Mostly, I noticed the lack of power! A whopping 85hp! Forget flying with 2 occupants if temperatures are over 90deg.
Rudder and elevator are very restricted. You can stall one, but it has to be a “whip stall”. (Abruptly pulling up on the controls in a bank). But the stall is unremarkable. The last one I flew had a O-200 Continental 100hp engine and rudder pedals, and was licensed as an Experimental a/c.
The most memorable flights was checking out a former Vietnam F-4 pilot in one that had belonged to a couple of former students. The F-4 pilot had been shot down and incarcerated in the “Hanoi Hilton”. He broke both legs on ejection and was badly abused/mistreated by the VC.
He could barely walk, and when the Ercoupe was classified as a light sport aircraft, not requiring a medical certificate, he took a “discovery” flight with me as the plane was for sale. We had a BLAST! He joked and said the Ercope flew just like an F-4…
fully loaded with weapons and fuel on a hot day below 200kts… We all busted out laughing!
With no rudder pedals or flaps, just a single brake pedal in the middle of the floor, he could still fly unassisted. He flew it (with me along) from KPIM to Mallards Landing (private paved airport), unassisted, so I signed him off for a BFR and make and model. (After a couple more familiarity flights). .
The most bizarre thing about the Ercoupe is landing in a cross wind! You approach the runway in a crab, and touch down in a crab! The shock absorbed trailing link landing gear allows up to a 25mph demonstrated cross wind component. It feels like a “controlled crash”…
We climbed at 60mph, descended at 60, and cruised at 80…on 4gph. And yes, they have a battery and electric start…
Kind of like early Porsche 911 turbos? When the cast iron turbo kicked in mid way through a corner causing snap oversteer and sending the driver into the wall? Those were called "widow makers."
