- Joined
- Oct 3, 2023
- Messages
- 865
Or get ADVICS brakes and rotors from RockAuto and save a little. Its the same OE that makes brake pads for Toyota as Denso does for engine compartment parts.I would not spend the extra for OEM brake pads or rotors.
I would on my 2005 Silverado with 250k miles because I count on it for work every day and it's not on its last legs or anything yet. It's getting 20-25k miles a year, driving to construction sites, through farm fields and trails. I put too many cheap aftermarket parts on and then they're failing again within a few years.Would you spend the money on OEM parts on a vehicle that is 9 years old and has a quarter million miles on it?
I did last week, front rotors and pads, shims for my 2015 Lexus RX350. This was the second brake job on the front that I've done on it, the first I chose to use the PowerStop OE rotors and pads. I'm done with brake components from that company. I have had absolutely horrible service from anything from Powerstop. I put the premium Z23 rotors and pads on my Tundra and they didn't make it 40k miles before the vibration was just too much.
I spent about $100 more in Toyota OEM parts than the Powerstop package of rotors and pads. The Powerstop stuff on the RX350 didn't make it 35k miles before the pulsation was just too much. Now the car has pretty much brand-new factory fresh brake components all the way around. I rebuilt the front calipers 35k miles ago, every seal/etc on them looked brand new at 190k miles. I was impressed. Saturday I do as I always do, wire brush the daylights out of the hub, wire brush the pad bracket, clean the caliper pin sockets with brake clean and booger-remover paper towel rolled up and shoved down in there, clean the pins and re-grease with a light coat of Sylglyde. I use the Toyota grease on the backs of the pads. Did the rears about 4 months ago with all OEM rotors and pads and same procedure. I always flush the fluid before beginning a brake job and then do a couple of bleeds after the pads are in.
Better than 99% of the shops out there are going to do.
Same here, I wonder if you got the "Toyota Service replacement" instead of what the factory slapped on.Except once your car is out of production your likely to get the cheapened "approved updated OEM part" anyway.
I’d say your dealer has abnormally low prices.I just looked up the ADVICS rotors and pads for my 2015 RX350
Rotors and Pads, $215 before shipping.
I paid $195 for the Toyota/Lexus OEM pads and rotors.
How much would I have saved at Rock Auto again?
I don’t understand about mileage and OE parts? If you get into accident, is it going to be less severe because it is older car? Brakes, suspension and tires, I NEVER save money on that.
That being said, Toyota OE brakes are junk. That is part where some aftermarket options are far better (EBC, Hawk, Pagid).
I had Pagid on Sienna. Huge improvement. Pagid is OE on Porsche, BMW, MB etc.Pagid pads for the OP's 2015 Lexus RX330 are only $30-40 a set. They also ship from the same warehouse as the Powerstop rotors![]()
Where do you find name brand brands? All the auto parts stores ever have is Wagner thermo quiets, then whatever house brand name they have.Depends on the part. But for brakes, nope. I’ve had good luck with Raybestos.
Definitely getting harder. Rock Auto has everything - but there customer service doesn't exist. I order a couple things at a time so I can't get hosed too much of it goes South.Where do you find name brand brands? All the auto parts stores ever have is Wagner thermo quiets, then whatever house brand name they have.
