One of my friends has started using an impact driver (not impact wrench) to remove and reinstall spark plugs on cars that come in.
He says his procedure is to break the plugs loose (slightly), then use an impact driver to remove the plugs. For reinstall, he says he screws the plugs in by hand for the first few threads, then runs 'em down with the impact driver...and finishes off with a torque wrench.
With this procedure, he's claiming that he is able to do the job in under 40 min while the book time is around 100 minutes.
Now, with a cold engine, assuming that the impact driver is not exerting a large amount of torque - I can see this being safe. Mazda put out a TSB a while back (#01-036/06) stating to never use impact tools to remove/reinstall plugs, but after watching the recent Ford 5.4 video, I wonder if it's actually a viable time-saver if done properly?
Thoughts? Personally I'm not brave enough to try it, but...
