I recently mentioned that I remove and inspect spark plugs every 20k miles or so to inspect them. Depending on their condition I may install the same spark plugs up to three times before replacing them. Someone said retorquing spark plugs was not recommended due to the crush washer being a one-time-use item. While I do not necessarily disagree with the sentiment in general, practically speaking I do not believe that torquing a spark plug repeatedly is more likely to cause any problems than is the gamble of letting fouling potential issues go unnoticed. If the washer was not sealing well there'd be visible signs of blowby making it past the threads and the washer.
The crush washer ensures a good seal between the seat of the spark plug and the spark plug. The washer is made from a soft alloy Depending on application, the seat is either flat or slightly tapered. Below are two pictures of an NGK crush washer that has been torqued three times over its life. Even after being torqued three times this hollow crusher still has some "give." and has not been completely compressed. I do however not torque to the high end of the specified torque range. I can't tell what alloy the washer is. Other than a more dull grey, the washer is light, soft, non-ferrous, and similar to aluminum.
Tapered seat
The cross-section of the reused crush washer shows it hasn't been compressed completely after having been torqued three times.
Tapered seat
