Well, I guess that's difference between a good independent shop, and a flat rate shop...
I guess it would be a brave service writer to tack on 5 minutes for cleaning the work area, but I think it would make sense to a lot of customers in the rust belt or rural areas where dirt often needs to be removed before you work on an engine. I think most people would be fine with that.
I guess if the coils are sealing normally, there should be next to nothing below. But if you can't see the back bank well and dump a teaspoon of sand into a cylinder... Probably the customer will never know, but its pretty poor workmanship, and potentially a serious problem.
