I had ngk dbl platinum spark plugs installed and then i got home and read on ngk is website not to use anti-sieze so Im not happy that the mechanic used anti-sieze on the plug threads even though it was just a lil dab on each and but he hand tighten them which is a good thing at least.
Ngk website says=Applying anti-seize to the threads of spark plugs that have a metal plating allows the installer to mistakenly over-tighten the spark plug in the cylinder head; This stretches and fatigues the threads of the spark plugs, causing a much higher probability that the plug will break during installation or in some cases upon removal.
I hope all is good for me
