Hi all.
I have bin reading a lot of threads about VAlvoline synpower. With big interest because I use it in my own car. I believe it is a good choise for my car. Synpower is for several reasons not very popular here on bigot.
when Looking at datasheets for some synpower oil. I realized the US synpower and synpower sold in Europe are not the same.
US synpower 5w30
Test 5w30
Vis @ 100°C (cSt)10.7
Vis @ 40°C (cSt) 59.5
Viscosity Index 172
Spec Gravity @ 60°F 0.847
Density(lbs/gal)7.06
Total Base No. 8.7
Flash COC (°C) 223
Pour Point (°C)-42
CCS cP (°C) 4300 @ -30
MRV TP-1 cP (°C) 18,000@-35
NOACK, wt. % loss 10.0
Sulfated Ash 0.93
Zinc/Phosphorus, wt.% 0.083/0.076
Sodium, wt% 0.049
Calcium, wt% 0.211
European synpower
SAE Viscosity Grade 5w30
Viscosity, mm2/s @ 100 ºC. ASTM D-445 11.9
Viscosity, mm2/s @ 40 ºC. ASTM D-445 71
Viscosity Index ASTM D-2270 165
Viscosity, mPa.s –30°C. ASTM D-5293
TBN, mg KOH/g ASTM D-2896 10.2
Pour Point, ºC ASTM D-5950 -42
Specific Gravity @ 15.6°C. ASTM D-4052 0.854
Flash Point, PMCC, ºC. ASTM D-93 206
Wich one do you bitbogers think is the best?
I can see the tbn is higher in the euro versio n. Is it good for long drain use?
Thanks all
Søren
US synpower 5w30
Test 5w30
Viscosity Index 172
Total Base No. 8.7
Flash COC (°C) 223
Pour Point (°C)-42
Sulfated Ash 0.93
Sodium, wt% 0.049
Calcium, wt% 0.211
European synpower
Thanks all
Søren
