So, you have no data of any sort to substantiate your claims other than product advertising and promotion material, which by itself is not data. I'd have thought the companies that produce these products would have at least published some test or research results that support their claims.My argument is based on personal experience and also product description of multiple more or less reputable products:
What data do you want? An excel sheet of blow by with and without ucl? I dont have that
"... more or less reputable products:" ??? Such a comment is not a ringing endorsement.
I poked around a bit and found this result of a Before and After test of Restore and below that is a link to the video that shows how the test was conducted.. Apart from a very small difference in compression for two of the six cylinders, there doesn't seem to be any improvement from using the product. Considering that the Before and After portions of the test were done under different conditions, I'd be inclined to suggest that there was no improvement of the type you've been touting. I've added a link to the video so that you can see how the test was conducted.
https://bleepinjeep.com/video/restore-engine-compression-10-does-it-work/
