I would too. But if I’m honest I would prefer something different.I'll take the thin Pennzoil over the thick Quaker State
Well I'm not a chemist or anything, I watched the oil geek, and he saw no GTL thereThere is some evidence out there that QSUP uses GTL too though
That is one thing I like about using M1 ESP is that all of the viscosities use better base oils than vanilla M1This is BITOG, why not go for POA/Ester/AN!! How I long for the Tri Syn days. Oh wait Dr. Rudnick formulates for HPL!!
Too expensive for a regular car.This is BITOG, why not go for POA/Ester/AN!! How I long for the Tri Syn days. Oh wait Dr. Rudnick formulates for HPL!!
Agree 100%. For ~ $28 it can’t be beat.That is one thing I like about using M1 ESP is that all of the viscosities use better base oils than vanilla M1
Only if it’s not used to it’s full potential. A case where a UOA actually makes sense.Too expensive for a regular car.
I've said this many times before, I cannot trust the stupid oil filters. So if I jack up my big ass van to change the filter, might as well just open the valve and change the oil. I have 4,600 miles as of right now on the hpl 0w16. when I get the oil filter dissected at 6,000 miles and if I see some stuff, I might switch to HPL and then run it for 15,000 milesOnly if it’s not used to it’s full potential. A case where a UOA actually makes sense.
Good point. This is where a cartridge filter is superior and why I don’t like using one filter for multiple oci’s.I've said this many times before, I cannot trust the stupid oil filters. So if I jack up my big ass van to change the filter, might as well just open the valve and change the oil. I have 4,600 miles as of right now on the hpl 0w16. when I get the oil filter dissected at 6,000 miles and if I see some stuff, I might switch to HPL and then run it for 15,000 miles
That wasn't the argument you were making, you were talking about additives.QS is not GTL
My point is that Pennzoil gets the job done with less additives while QS needs more additives. So more additives don't mean anything. So it must be the GTL that is playing a part. Not my words, it's what that oil geek on YouTube said.That wasn't the argument you were making, you were talking about additives.
I think historically QS might have continued to use Shell's XHVI base oils, and perhaps it is still the dominant base in some of the products, but here's the SDS for the 5W-30:
That "Distillates (Fischer-Tropsch)" is GTL.
All other things equal I would still prefer to have GTL over the other versions of group 3 base oils though…
I'm in agreement. It really is the end product that matters.I don't think this is correct, I'd be fascinated to see the evidence supporting this and have my skepticism enlightened. I doubt anyone would pay a premium for expensive co-base or tribase blends if there was no payoff in engine wear.
Additive concentrations in PPM only trick us in to thinking we know things we don't. I recall a recent LSJr video comparing M1 15w50 and VR1 20w50 in SP grades vs SN grades. Both adds packs are "weaker" for SP and yet both oils showed less camshaft wear in the SP formulations. Less wear with lower additive concentrations.
I seem to recall the striking finding that the new VR1 dino oil was actually better than the previous synthetic M1 15w50. So not only did the oils gets better with the "weaker" add packs, the improvement was enough that the newer dino outperformed the prior synthetic, and by a notable margin.
There are lots of ways to skin the cat and there are great oils out there with high boron levels (300+) and great oils with zero boron. Moly levels are all over the place. Higher SAPS vs mid SAPS might be better or worse-- one can find cases of each.
It's recipe vs recipe, not ingredient vs ingredient.
Exactly. I keep things simple. All these big brands are good, buy the one that offers a better deal. I have hoarded both Mobil1 and Pennzoil.I don't think this is correct, I'd be fascinated to see the evidence supporting this and have my skepticism enlightened. I doubt anyone would pay a premium for expensive co-base or tribase blends if there was no payoff in engine wear.
Except I just showed you the VOA's that have basically the same additives, so....My point is that Pennzoil gets the job done with less additives while QS needs more additives. So more additives don't mean anything. So it must be the GTL that is playing a part. Not my words, it's what that oil geek on YouTube said.
I thought you had no faith in VOA'sExcept I just showed you the VOA's that have basically the same additives, so....And of course I also showed that QS uses GTL.
