Cool idea on the vacuum. I'm half tempted to try it next time I do an oil change, just for kicks and giggles. But it really doesn't matter much to me. I have a Fumoto valve on my wife's Outback, and use an oil extraction pump on my E350. So no mess, no fuss. Never have to worry about where the drain plug is going, or how to hold on to it.
Most Oil Experts Say It's Better To Drain The Oil When It's Hot Instead Of When It's Cold, For Several Reasons:
- Oil viscosity is thinner when it's hot, so it drains more quickly and completely out of the engine than when it's cold.
- On a hot engine, contaminants are more likely to remain suspended in the oil than when the oil is cold, increasing the chances they'll be expelled from the engine during the draining process.
- Today's high-tech OHC engines hold oil in a lot more places compared to old-school motors, so it's gotta be warm (and thin) to escape from all those upper-end crevices.
I think everyone agrees that hot motor oil drains more quickly than cold motor oil. But the second and third reasons really seem theoretical at best, and actually sound a little like junk science.
The whole idea that there are solids that will fall out of suspension if the oil is allowed to set in the sump overnight, or even a few days, seems absurd. First, the oil filter is supposed to be capturing particles down to the size than it is rated for. Second, modern motor oils are designed to keep the remaining particles in suspension, in such a way that the particles do not cause wear.
If the theory, that particles fall out of suspension in just a short time, is valid, then the theory that they will be sucked back up, off the bottom of the oil pan, just by running the engine for a few minutes, doesn't seem valid.
The third item is also a little absurd. Assuming the motor oil was up to temperature whenever the engine was last shut down, then the oil is going to drain out of all these thin "crevices" at that time, and end up in the sump. So, if you drain cold, you are going to capture as much as possible, that would have been in these "crevices". If you drain hot, you have just pumped oil up into all these crevices, only to have to wait for them to drain, again.
IMHO, the only valid reason to drain hot is convenience. And if you use an oil extraction pump, hot oil is a major convenience. But until someone has data to show that a hot drain captures more crud, I'm a non-believer.
