Ultra Platinum or Restore and Protect
NY
Walmart carries both for $30.
What one are your getting and why?
Both have their strengths. Valvoline Restore and Protect if you have an engine that consumes oil or you bought used and suspect it might have been neglected. PUP is a great choice for engines that are new or already fairly clean. Once I’m done running a few intervals with Valvoline Restore and Protect I may just go with PUP in my Civic (it’s on my short list, also considering Mobil 1 Extended Performance High Mileage or Castrol EDGE Extended Performance)
I like Valvoline Restore and Protect's claims of cleaning so would go that route if consumption was high. Unfortunately, only places like Australia get 10w-40 Valvoline Restore and Protect so not many options above 5w30. Ultra should be a very fine oil & have run it without hesitation. Matched with a Pennzoil rebate makes it pretty good deal.
Pennzoil ultra Platinum if consistently available would be my choice. I like the fact that it's blended with natural gas and I trust it more and I honestly can't explain why.
Natural gas GTL oils have some great properties but Pennzoil isn’t the only oil in town that uses them. Just look at the sds for restore and protect
Valvoline Restore and Protect 0w-20: 60-80% GTL
Valvoline Restore and Protect 5w-20: 45-70% GTL
Valvoline Restore and Protect 5w30: 30-60% GTL
I've been on the PUP train for a while for several cars in the family that I maintain. Had great experience with them thus far. But for these same engines (0W-20 and 5w30 uses), I'm switching to Valvoline Restore and Protect. The reason? I want very clean piston oil control rings.
Can't speak to the PUP, which I'm sure is a fine product, but I posted a used oil analysis for Valvoline Restore and Protect in the subforum. Long and short, the wear metals in the 5000 mile used sample were indistinguishable from a virgin sample. In other words, basically zero wear metals detected that could be attributed to engine wear. That's a fairly compelling reason for me.
I have not pulled any used oil analysis on my 3) 3,000 miles fall-spring and a 4th Valvoline Restore and Protect is up coming in 2-3 weeks, late spring and summer my car will get my stash of 5w-40 Motul 8100-Clean Gen2. This Valvoline Restore and Protect 5w30 has been the cleanest running oil ever in my car. Nothing has run cleaner as far as color, most all my top tier brands ( Amsoil, Redline Performance Euro, Mobil 1 Extended, Mobil 1 ESP /2 years, Pennzoil Ultra, and Motul), run to black at my 3,000 mile dump, this stuff is still in the brown/black color. I think I will pull a used oil analysis and send it to the large local CAT dealers lab where I have a couple other pulls. No need for Polaris Lab, since I no longer have massive fuel dilution problems like I use to have.
PUP is too hard to find locally, so I ran PP for the better part of a decade and my Odyssey varnished pretty heavily on the OLM interval. So I'm running Valvoline Restore and Protect now and it's visibly cleaning things in the overhead.
It's not really hard data, but more like one man's anecdotal experience, so that suggest to me Valvoline Restore and Protect is the better option.
It's another matter entirely as to whether that difference matters.
I had used Pennzoil Ultra Platinum for 7 years back from 2013 to about 2020. It was more expensive than most other oils during that time.
I never noticed any benefit from it whatsoever. I don't even own that car anymore. Money wasted that I can never get back.
Now, I just use SuperTech High Mileage Full Synthetic 5w30 at 5,000 mile OCI. I'm convinced that using either Pennzoil Ultra Platinum or SuperTech High Mileage Full Synthetic Dexos 1 Gen 3 for 300,000 miles would yield identical results if the engines were opened.
I have 4 vehicles that various family members use for very long commutes totally 34k, 20k, 20k, 10k miles a year.
So the savings will be about $1,000 over the next 6 years by using SuperTech High Mileage Full Synthetic versus Pennzoil Ultra Platinum.
Good to know 😃. Thanks buddy 🙂
iirc Valvoline Extended Protection High Mileage is mostly GTL according to the sds sheet, you also see it in a lot of Mobil 1 oils. None of them make it a marketing point like Pennzoil does.
It’s like when I learned castrol edge 5w-50 had a high level of zddp that most other oils make a big deal to point out but their marking angle is focused on the power of titanium.
would you be able to post a link? can't seem to find it.
