Natural gas GTL oils have some great properties but Pennzoil isn’t the only oil in town that uses them. Just look at the sds for restore and protectPennzoil ultra Platinum if consistently available would be my choice. I like the fact that it's blended with natural gas and I trust it more and I honestly can't explain why.
I see there was a recent revision. Now using GTL. Good to know, thanks.Natural gas GTL oils have some great properties but Pennzoil isn’t the only oil in town that uses them. Just look at the sds for restore and protect
Valvoline Restore and Protect 0w-20: 60-80% GTL
Valvoline Restore and Protect 5w-20: 45-70% GTL
Valvoline Restore and Protect 5w30: 30-60% GTL
Can't speak to the PUP, which I'm sure is a fine product, but I posted a used oil analysis for Valvoline Restore and Protect in the subforum. Long and short, the wear metals in the 5000 mile used sample were indistinguishable from a virgin sample. In other words, basically zero wear metals detected that could be attributed to engine wear. That's a fairly compelling reason for me.
Good to knowNatural gas GTL oils have some great properties but Pennzoil isn’t the only oil in town that uses them. Just look at the sds for restore and protect
iirc Valvoline Extended Protection High Mileage is mostly GTL according to the sds sheet, you also see it in a lot of Mobil 1 oils. None of them make it a marketing point like Pennzoil does.Good to know. Thanks buddy
would you be able to post a link? can't seem to find it.Can't speak to the PUP, which I'm sure is a fine product, but I posted a used oil analysis for Valvoline Restore and Protect in the subforum. Long and short, the wear metals in the 5000 mile used sample were indistinguishable from a virgin sample. In other words, basically zero wear metals detected that could be attributed to engine wear. That's a fairly compelling reason for me.
Pennzoil coupons good til August.Both. PZ when it’s rebate time. Valvoline Restore and Protect just to try something new cause why not.
