- Joined
- Jan 8, 2024
- Messages
- 278
What's the time difference in immediate action for a fail to fire on a revolver vs a semi auto? I'll give you a hint, with a revolver you just pull the trigger again.
I some cases, a revolver is the better option, even for civilians. Limp wrist a small 9mm auto and you may only get one shot before having to clear it. Then there's the secondary problem of the user not having sufficient hand strength to rack the slide. Both platforms can fail, no doubt about it. But a semi auto carries the additional chance for failure due to shooter technique, or more appropriately, lack there of and a revolver will function if the trigger is pulled, no matter how the user holds it. (Assuming no mechanical failure)
As someone who worked a career in law enforcement in a variety of assignments including uniform, planclothes and SWAT, I can say without a doubt in some cases a revolver is superior because it will do things an auto can't. For instance, fire from a pocket or other confined concealment more than once, the same goes for firing more than once with another man's hands holding on to it. The inherent safety of a double action snub allows it to be carried in the best position for rapid deployment without taking on additional risk of an AD/ND into one's own femoral artery.
In the last the ten years the internet has become rife with "firearms experts" and "internet gunfighters" who don't have true experience and don't know what they think they know. I will say this, they can be mildly entertaining.
