- Joined
- Jan 1, 2024
- Messages
- 39
I looked at a .38 and a 9MM. How would the recoil differ with the same grain bullets? Stopping power difference? No plus P+ used.
That is a myth. They are still mechanical devices and capable of malfunction. The biggest problem with revolvers is when they go down, they go down hard. There is no tap rack drill to clear a simple malfunction.One of the major benefits of a snub is 5-6 for sure bangs.
Yes, they do. Hence why I try to steer people away from revolvers that are chambered in semi-auto calibers.Do modern revolvers chambered in 9mm still require the use of moon clips?
Very similar to the point of being inconsequential. The 9mm having a slight edge.I looked at a .38 and a 9MM. How would the recoil differ with the same grain bullets? Stopping power difference? No plus P+ used.
I have a broken Charter Arm .38 in my safe that is a paper weight due to lock up and timing issues. Not worth fixing honestly. It dispelled the myth for me that revolvers were a sure thing.
It is absolutely a myth. Anything can malfunction. If a loose primer backs out (which can happen) it could lock up the gun. Never happening to you and never being able to happen are two different things. The notion that a revolver can never fail you is a myth.I've heard Charter arms is pretty good about fixing them if they have issues, assuming yours isn't an original one that's 50yrs old.. I have a couple ones made by the current company and they work fine.
Really though it isn't a myth, if you buy a S&W or a Ruger revolver...
OK. Skateboards and cars are both mechanical devices...one more likely to malfunction vs the other.That is a myth. They are still mechanical devices and capable of malfunction. The biggest problem with revolvers is when they go down, they go down hard. There is no tap rack drill to clear a simple malfunction.
9mm revolvers...for the sole purpose of self defense/ccw are a glaring example of just because you can doesn't mean you should. Speed loaders vs moon clips?? There's a reason why cops were never issued 9mm revolvers.The beauty of a small revolver is it's simplicity. For me, moonclips for auto ammo, seem to take away a small amount of it IMHO. Something else to go wrong and harder to reload in a firefight if needed (unless you carry a full moon around with you). I mean if one of those rounds isn't clipped in properly, it could get tricky. But thats just me.
Ballistically, you have a broader range with the 9 over the .38, but neither should make a small revolver unmanageable, unless you choose something incredibly hot, as far as recoil goes. "Stopping power" depends on many other factors than just the ammo. Suffice it to say, either a standard 9mm or .38spl., shot from a short barreled firearm, will have similar terminal effect, ie; on the lower end of scale. Having said all that, my small revolvers will be chambered for cartridges with case rims and a +P designation.
Revolvers can fail. Sorry that hurts the feels.OK. Skateboards and cars are both mechanical devices...one more likely to malfunction vs the other.
You cheaped out. Should have bought a Smith or Ruger ... arguably a Taurus. You went cheap and it cost you. I won't argue best carry option. That's a total personal risk analysis. But a revolver, by it's very design is simply more reliable than a semi automatic pistol, fact, not myth.
