TV shopping
I run an Apple TV box since I’m all Apple. Everything else isn’t as quick in my experience.
I agree. I have a 1st and 3rd gen Apple TV 4K on different TVs, and both are so much faster even than the Roku Ultra which I had previously. Even if you’re not in the Apple ecosystem, their processing power still makes them the top choice IMO. I don’t even pay attention to what OS the TV comes with anymore.
I do the same. Have been using appletv for quite some time now with great results.
OP, is it possible a 55" has the same physical dimensions of your current 50" given its age and larger bezels compared to newer models? Just a thought. Otherwise, I don't blame you for holding to around that size based on your space...bigger is not always better.
I would certainly consider a sound bar...as others have said most all TV built in speakers sound like junk.
The current set has maybe at most 1/2" bezels all around. Anything bigger would require choosing which portion of the show to see and which portion would be out of range, like sitting front row at the movie theater. The current set is even slightly too big after rearranging our seating.
Worth noting that 99% of the actual information and content of programs new or old occurs in a square to the center of the screen.
+/- 5” won’t make a bit of difference.
Getting a “high end” set in 50” or smaller is getting more challenging as the number of options is quite small at those sizes. It’s almost to the point you could grab a curved monitor and a sound bar if you want high end features packed into those sizes instead of a “tv”
You might consider bumming around the Avs forum if you want to geek out.
Also worth noting more important than size if you are in a micro home is viewing angles, some of the very high end sets have mediocre viewing angles compared to some of the low end tech, so if this is an issue make sure you check out the thing in person
Heck getting a true 1080p screen 20-30” requires you to target used TVs around 10 years old because they only make 720p sets in those sizes as loss leaders. 40-50” is now in the value spectrum similar to a 32” tv 15 years ago.
As for me I’ve been happy enough edging towards to mid or lower end of the market with Vizio sets. YMMV. but ignoring apps a Vizio will be fine if you can get the color balance correct.
The higher/mid range are all Sony/Samsung/LG each with their own set of potential issues.
Just left Best Buy and a moderately traditional Samsung in the 50”ish size is $299.
As mentioned OLED, mini LED and other advanced sets don’t always have the excellent viewing angles in reality (despite hype) compared to more traditional sets (Avs forums go into a few examples of strange issues with it on specific oled sets)
I would definitely try to simulate your seating positions if your room is too cramped to see the screen without extreme angles. (I’m imagining a building column in the middle of the room in front of the tv)
We don't have extreme angles, maybe 2x% max from straight on. We just have a configuration that has one seat 6-7 feet from the screen and the other about 9 feet.
My wife and I did all of this a lot different than y'all.
First TV I never wanted in my life. I hated having any TV but my mom surprised me with a 19" color TV that had a VCR when I went to college.
I had it for 12 years and then I gave it to a friend of mine who did the administrative work at a dealership where I would consign my older inventory.
That TV easily yielded thousands in return since the cheapskates who owned the place never got her one. She sold a ton of my vehicles, and I always made sure she got payed directly in cash by your truly.
Then we got a 27 inch Apex CRT for $99 as a Black Friday deal in 2003. We also bought separately a VCR, a metal DVD player and a router that would let them all play well with each other. Add an antenna and a ton of library videos, and we did great for another 11 years.
Finally I decided to splurge a bit and let my wife and kids buy a 'modern' TV. We got two 42" Changhong flat screen TVs for $241 each and then Freecycled a 44" Samsung that isn't a flat screen or a Smart TV, but has tons of inputs.
We have one Changing downstairs that gets 95% of the viewing time. When that one starts deteriorating we're going to switch it out with the upstairs TV and then finally the Samsung once they're both headed south.
I hope to have this work until 2044.
Just avoid the oddball offbrands especially ones made for a certain retailer like Walmart etc as they use cheaper components, typically have smaller heat sinks etc.
If you mean Vizio - Walmart purchased them in 2024. Close as it gets to American owned but only designed in the USA …
Have them as bedroom TV’s …
