spasm3
If i have a box or cabinet around my TV, is there any reason i could not mount the bar above the TV ?
No need to run speaker cable, this JBL Bar is all you need.
If i have a cabinet or box around my TV, is there any reason, i could not mount the bar above the tv?I'm with @Malo83: just get the JBL soundbar and call it good. You can hook it up to the tv either with an optical cable or HDMI via eARC. I prefer using optical as it avoids all the handshake crap HDMI uses. Since you're just using the bar, not having HD audio (DTS-HD/Dolby TrueHD/ATMOS) won't make a difference.
OK, thanks!The bar really needs to be near ear level to function properly, putting it 6+' off the ground won't work well.
Might try this, tilts with the tv to direct the sound to your seating position.If i have a box or cabinet around my TV, is there any reason i could not mount the bar above the TV ?
Nice!Might try this, tilts with the tv to direct the sound to your seating position.
Sound could be a whole separate thread. What is your goal, decent sound for casual watching or closer to a theatrical experience? A sound bar is a minimum as pretty much all TVs' built-in speakers are inadequate. If you want theatrical and are a big movie watcher, skip the sound bar and do a proper Atmos setup if you have the means and the space to accommodate. Regardless, don't buy the system that you linked.OK i think i will go with that set ! Either in 75 or 85.
What sound bars, surround would work with it?
? https://www.bestbuy.com/site/logite...-system-6-piece-black/4580243.p?skuId=4580243
This is a wired system, i have to see if i can run wire through my vaulted roof trusses. Could a center channel speaker be mounted above the TV? I may use a swing down mantle mount.
Pull Down TV Mounts - MantelMount
Browse MantelMount's collection of above fireplace pull down TV mounts. Mount large flat screen TVs to a variety of surfaces including drywall, stone, brick, outdoor posts, beams and much more. Shop now and find the perfect pull down TV Mount for your home!www.mantelmount.com
Thanks, casual watching with better sound than the TV speakers. My plasma TV has poor sound. Seems all thin tvs do. Not after theater or audiophile sound, just better.Sound could be a whole separate thread. What is your goal, decent sound for casual watching or closer to a theatrical experience? A sound bar is a minimum as pretty much all TVs' built-in speakers are inadequate. If you want theatrical and are a big movie watcher, skip the sound bar and do a proper Atmos setup if you have the means and the space. Regardless, don't buy the system that you linked.
I’ve seen it mentioned on multiple home theater sites and “professional” viewing setups that for proper viewing aspect, you take the distance from the viewing spot and divide by two to get the correct screen size needed. Working opposite way, an 85” screen would have a viewing distance of 170”, or about 15 feet. Considering the size of the room, 85” is actually just a hair small. I have a 16’ square area with about 14’ viewing distance and a 70” screen and it’s too small. As a matter of fact, the 85” is about the perfect size for this distance, and what I’ve been eyeballing.I wouldnt go over 65" . A 85" TV is way to big for a 20 ft room .
