Turntable Static/dust/fuzz control
Everson WA - Pacific NW USA
My turntable seems to carry a static charge (+?) that really attracts all sorts of light particles (-?)
The cartridge plastic itself is a real magnet for stuff, but always something in there. I do use the plastic cover just to keep the daily falling debris out. I can clean a record and it plays just fine, but shut it all down, come back the next day and fuzz cling is back.
Is there any kind of help/solution?
When I had turntables, they always had lots of dust. I don’t know if mine were as bad as you describe but dusty just the same. I use to just keep them clean on a regular basis.
Anti-static brush, very common in the turntable world. I use this one: https://uturnaudio.com/products/anti-static-record-brush
I usually let it run through the record through a spin before dropping the needle each time. Doesn't take up a ton of time.
Yes I use this one: https://www.amazon.com/Bristles-Anti-Static-Cleaning-Essential-Accessory/dp/B0DNNPP1SG
Not much help everywhere else though.
Tried this, but seemed useless: https://www.amazon.com/dp/B07C4LHFVM?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
Ai says to use a cork, rubber, or cork/rubber blend for the turntable mat.
Is the turntable metal? I presume it would be grounded, if not, I don't see how it can be grounded without serious modification.
I tried a cork mat. Worse. Now I have a heavy composite mat. Improved a bit.
Metal and plastic everywhere. It’s grounded electrically and sonically fine
Decades back, I can't remember the brand I used. It came with a cleaner pad, and a solution you used a few drops of on the pad. It worked decent.
Similar to this:
Vinyl buddy
I was going to post a link, but no can do.......
