Shel_B
Site Donor 2023
- Joined
- Aug 7, 2020
- Messages
- 5,166
I'm running Toyota's WS fluid in the Camry. As far as I know, the car has had but one fluid exchange, back around February of last year. The exchange was done at around 80,000 miles.
Since the transmission has a fair amount of miles on it, I was thinking about wear, and I realized that I know even less about xmission fluid than I do about oil. So, a few questions:
Is it reasonable to use a more viscous fluid as the xmission ages, perhaps akin to going up a grade with high mileage engines? Might the heavier fluid affect mileage?
Should I decide to go to a heavier fluid, I'd probably choose something like Aisin WS, or Idemitsu WS (sp?) that are presumably closer to the Toyota spec (I would verify that through tables and comparisons that I have here). Would mixing a different formulation with the Toyota WS cause any issues? My thought was to add fresh fluid with a drain and fill rather than a full exchange, thereby giving something approximating a 50/50 mixture of the fluids.
Thanks!
Thanks!
