Originally Posted By: 350zriot
Originally Posted By: A_Harman
My experience so far with Mobil 1 Turbo Diesel Truck 5w40 in my truck has been high oil consumption, about a quart every 1500 miles. This is much higher consumption than I had with VPB Classic.
My experience with Mobil 1 5w30 HM in my Camaro was very low oil consumption, only 1/2-quart in 5500 miles. This is much lower consumption than I had with standard Mobil 1 5w30.
Since you live in SoCal, you don't need the low-temperature flow characteristics of a 0 or 5w oil.
The HTHS of HM 10w40 is 4.06, while for Mobil 1 Turbo Diesel Truck 5w40, it is 3.8. This means higher oil film thickness in your bearings.
The Flash point of Mobil 1 Turbo Diesel Truck is 215C, and for HM 10w40, it is 240C.
Because of the lower viscosity spread, HM 10w40 would be slightly more shear resistant than Mobil 1 Turbo Diesel Truck. And since the Nissan V6 engine is notorious for shearing oils, you need all the protection you can get.
Check out this sad story of a Nissan V6:
https://bobistheoilguy.com/forums/threads/my-rod-bearings-after-a-hpde.131922/
Could you tell me what all those letters stand for? like..Mobil 1 Turbo Diesel Truck, HD and such
i'm surprised that mobil 1 5w40 lost more oil than 5w30.
Shouldn't thicker oil lose less over time?
I was searching around autozone website, annd i noticed that they sell mobil 1 clean 5000 10w40 for half the price of other engine oil. why...?lool
HM = High Mileage
Mobil 1 Turbo Diesel Truck = Turbo Diesel Truck
Mobil Clean 5000 is not a synthetic oil. Only Mobil's fully synthetic oils bear the Mobil 1 name. It may have been on clearance because it is a nearly useless weight of oil, and Mobil Clean 5000 has been replaced my Mobil Super.
HM = High Mileage
