Originally Posted By: chevrofreak
Originally Posted By: Papa Bear
Originally Posted By: Tom NJ
Base oil quality is no longer defined by just three simple categories consisting of conventional, semi-synthetic, and synthetic. With the introduction of new processes and feed stocks over the past dozen years, we now have numerous base oils grades and blends thereof, resulting in a continuum of base oil quality, such as:
Grp I
Grp I & II blend
Grp I & III blend
Grp II
Grp II & III blend
Grp II+
Grp III
Grp III & IV blend
Grp III+
Grp III & IV & V blend
Grp III+ & IV & V blend
Grp IV & V blend
While the exact quality order of such base oil selections is debatable and dependent on component grade and ratios, the point is that the quality steps are now so small as to make labels such as semi-synthetic and synthetic difficult if not impossible to place. The industry chose to draw a line between Grp II and Grp III in defining “synthetic”, but the difference is merely a single VI point, and therefore meaningless from a performance standpoint.
Certainly there is a meaningful difference between the low end and high end of the spectrum, such as Grp I vs a Grp IV/V blend, but the difference between adjacent levels, and really even levels that are three, four, or five apart, is easily blurred by the additive system.
Hence, the great debate over “synthetic” versus “true synthetic” is dead. The use of the word synthetic today only signifies that the base oil blend leans toward the higher end of quality continuum, and translating that further into finished oil performance becomes a stretch.
Unless you have a special engine or driving conditions, you are better served concentrating on specifications and approvals rather than base oils for estimating oil performance.
Tom NJ
Tom, that's great !! We could designate our synthetics on a scale of 1 to 10 ......
Grp 1 & 2 blend could be "Full Synthetic (1) Oil"
Grp 2 & 3 blend could be "Full Synthetic (2) Oil"
..etc....etc.
No.. wait... that would be far too simple and straightforward
That wouldn't work, since a Group I and II mix contains no synthetic oil, and a II and III mix would be a synthetic blend.
Come on, it could at least be a "conventional" blend.
Grp I
Grp I & II blend
Grp I & III blend
Grp II
Grp II & III blend
Grp II+
Grp III
Grp III & IV blend
Grp III+
Grp IV & V blend
Tom NJ
..etc....etc.
